I had a code stored when my abs kicked in for no reason. Checked again later and got different code. Gave up when i checked again (different code again) after I about rear ended a car. Pulled the abs fuse and removed abs bulb. 285/75-16 tyres, stock gears. Later removed the ABS and LSPV and got a adjustable valve.
As long as all tires are the same diameter,size shouldn't matter. When the computer reads one wheel is locked, the computer triggers the brakes to reduce braking while pulsating.
I dont think the 95+ Fzj80 have traction control TRC and or vehicle stability, do they?
My son's 2004 Rav4 is having the traction control triggered for no reason.
Possible causes from Toyota are:
hard tires (they said to use softer tires)
worn shocks (dont use stiff shocks)
worn bushing in the rack and pinion
My thought is the abs system back in the 90's was new technology and they didn't have all the bugs worked out. After so many miles or years the system starts to fail, then it gets thrown into the recycle bin.
