Write-up: Toss the LSPV and install a manual proportioning valve
You could also just pull the connector(s) at the ABS computer.. then there is nothing to turn the light on in the first place. This would likely be less work than pulling the combination meter to get at the bulb.
Edit: nevermind. Looking at the schematic, you'll have to pull the ABS relay plug(s) as well as the ECU plugs. Should still be less work than pulling the cluster, though.
Finally found it! Rockjock82 says "Send 12v to the only pink wire on your ih2 connector. This will turn it off"
This thread is convincing me more and more to chuck the ABS and the LSPV all at once. As long as I can retain the cross braking ability (safety), I might follow suit.
If I had known now then I would have yanked it all out much earlier. I had some erratic pulsing on the front DS caliper before and haven't had it since removal. Not a big fan of ABS nor the LSPV and glad they're gone, one less thing to fail at the least opportune time.
I'm a liability type of guy and don't try to do things that place more of it on me. However,, I think that someone could also say that since I've placed a 4.7L V8 in a truck made for an inline 6 that I'm just as liable as removing the ABS..
The valve says " 1,000 Max psi," for the Wilwood Brake Proportioning valve 260-12627
The FZJ80 goes well over 1000 psi. I have reading up to 2000 psi with my gauge.
IS the valve gong to handle the pressure of the brake system?
I'm going to start this process soon and was planning to install the valve just as insurance. Wilwood says all their valves are good to 1200 psi, but this is still way under what you're seeing. Where and how are you measuring 2,000 psi?
From when I got the gauge.
"Got my SSB Brake Gauge and after flushing the old brake fluid I got some numbers.
Not sure how mush you push on the brake pedal so I had my helper push as hard has he could.
Front 2000 PSI
Rear 900 PSI
Thats a 69 31 front to rear ratio.
This is with an unadjusted LSPV and 2.5 Med OME lift.
The gauge works nice but you need a helper. If the gauge had a lock where the pin would lock on the highest pressure like on a compression gauge, you could use the gauge alone"
Just did the ABS delete, are the fittings the same that get tied back into the tee under the master cylinder? The two lines that move from the abs to the tee seem to leak even though they are tight.
Sent from my SM-G900R7
Did you miss the 1st post:D
I've read this post several times a while back and for the life of me I don't ever remember seeing that!!
You didn't just go back and put it in there to make me think I'm crazy did you?!
Thanks Phil!
Thanks for the write-up @jcardona1. Ditched my LSPV and ABS last night. Untested as I need a full bleed, but I already have a firmer pedal! I assume this will be a huge relief know I can actually make a stop.
Yeah, let us know how the brake feels. I'm teetering on the edge....
I'll be joining the club soon as the weather turns. Got a log jammed above the rear axle while at Rausch Creek last weekend, took out the sensor wire in the process.
Deleted both this weekend. No prop valve used. Took ages to bleed all air out but the braking is WAY better
Note:
With no LSPV your rear brakes will lock up sooner than the fronts. Its will make you butt pucker for panic stops on grooved and banked roads. Wet pavement will increase the pucker meter. I recommend you find a vacant road and do some panic stops. Find a road with a strong crown and do some panic stops on both sides of the road so you know how the vehicle will react (spin out) when you panic stop. Mine would spin out like pulling a parking brake when turning, a bit scary. With the adjustable proportioning, the problem is resolved.
Note:
I think that's often repeated but isn't always the case. Ever since I did this mod I've left the valve fully open. I've did a few test stops where I SLAM on the brakes with all my weight. I can lock up the tires no problem. But I never felt the rear brakes locked up first. Several others have said the same when running no LSPV at all. My guess is tire size and overall weight may affect each truck differently.
RESULTS: By far the BEST most recent modification I have made. Ditch that LSPV and ABS! I would have to say it was the ABS that was causing the soft/spongy pedal. Gravel test: Lock up both F/R at the same time per @Cruzerman. <--Thanks for the help with the two man bleed. I could hardly even get the ABS to go into action on gravel before this. In low, with ABS disarmed, it was a stretch to really skid all four on gravel (Q78 Super Swampers). I approve of this deletion lol. I'll do a concrete jungle test tomorrow with my commute to work.
