'I' might be ready for a Turbo, but East Texas isn't ready for Flint with a turbo.I'm thinking you're ready for a turbo now![]()
I marked the "W" on the top of the Wilwood proportioning valve. At full open, the rear would lock sooner than the front. I set it to 3 turns from full open. I recently replaced the brakes and found the rear brake pads almost gone with a decent amount of meat still left on the front brakes. I installed new OEM pads (100 series in the front) and set the proportioning valve to 6 turns from full open. I think I measured 15 turns from open to closed.I can't say conclusively just yet. I keep about 350 lbs of tools, etc....in the back of my Land Cruiser at all times so my LSPV was adjusting for that already. The little bit of testing I did with the proportioning valve this morning was on dirt, gravel and grass.
With the valve fully open (spring pressure actually)....the rears definitely locked up before the fronts on gravel and grass. On hard pack dirt it seemed it was a good balance. I haven't had it on pavement yet.....so can't say what the final adjustment will be (if any) at this juncture. But I promise....I will post back here when all done.
I like having the ability to adjust the rear brake participation.....whether I ultimately use it much or not.
Thank you for the link!Takes some experimenting to find the best setting.
A P-Valve doesn't operate like many folks think (like a gate valve). The adjusting knob/shank simply applies more or less pressure to the spring inside the valve which establishes pre-load on the piston. In essence... it is a pressure regulator that we can set to operate at a certain pressure threshold. The ratio is predetermined by the piston.
The valve actually does nothing during normal driving/braking situations.
With respect to nomenclature... the easiest way to describe the setting is to refer to it as being more Open or Closed...even though that isn't what is taking place inside the valve.
How Does a Proportioning Valve Work? And How Do You Adjust It? – Wilwood Store
When setting up a street car for performance driving or converting a classic to disc brakes, it is essential to include an adjustable proportioning valve in your brake system. This valve is typically plumbed into the rear brake line or built into the combination valve below the master cylinder...shop.wilwood.com
Excellent information, thank you for that. I needed this education as well.Takes some experimenting to find the best setting.
With respect to nomenclature... the easiest way to describe the setting is to still to refer to it being more Open or Closed...even though that isn't what is taking place inside the valve. Knob position In or Out is actually what we do and what controls the pressure threshold for activation. I only mention that so folks understand the two terms mean the same thing.
Doing this later today. @flintknapper Can you share any pictures?I saw multiple ways of getting this done in different threads.
Deleting both. Using a flying miata kit, willwood valve and thread adapters. Ordered few extra 3/8th 8’ universal brake lines. Plan was something along the line ofYou deleting both ABS and LSPV?
Will you be using a manual Proportioning Valve....or no?
MC (rear line) -> thread adapter -> universal brake line -> prop valve -> universal line into toyota line.
Now that I wrote it out, I think I’m missing an extra elbow or male to male joint fitting. Maybe I can bend OEM brake line. I’m not sure how long the rear brake line is, if it can reach to the prop valve.
Awesome sauce Flint, thank you for taking the time to write this up, amigoWhen you get to the LSPV you will see that it has 3 lines. One of the lines ( the lower left) is the 'sense line' that goes from the LSPV to the 'Tee' under the Master Cylinder (in OEM configuration). This line will NOT be used again and can be removed or left in place but it has no function for us any longer.
The two upper lines on the LSPV are what we need to join together. Some folks use the 'L' removed from the line up under the drivers side wheel well. I chose to simply use a 'Tee' that I already had and blocked off one port. Others have bent the factory lines and use a simple coupler. Whatever you decide is fine. Just join the lines together.
IF you need pics of anything else or have questions, just let me know. I have other pics, just trying to keep this brief.
Just to clarify if just deleting LSVP for now, I join the two lines at the rear as described above. That i'm clear on.
Then under the hood you just need to connect ports #2 and #3 in this pic from the original post?
this might be helpfulJust to clarify if just deleting LSVP for now, I join the two lines at the rear as described above. That i'm clear on.
LSPV deleted. Rebuilding the rear and then we’ll see how it feels.
View attachment 3258358View attachment 3258359
