ARCHIVE Wits' End Turbo Test Mule #3- no cartwheeling allowed (5 Viewers)
When is the twin coming
Hood looks great! I just painted mine and have been looking into the best material for replacing the heat shield. OEM pad seems pricey. What did you use there? I'll be ordering your rubber seal kit next to clean it all up!
Kept the original pad but painted it.
I run 50/50 (by volume) methanol and distilled water. Methanol can be found in 5 gallon cans but you have to look for it. I bought this can a month ago for less than 30 bucks. It lasts me quite a while. View attachment 2020887
I love the no-nonsense label here. "You'll die, for real"
Got to love it. Big 3" lettering....(you could read from across a parking lot).
Gives one the impression 'they really mean it'. :)
Man, those are some sharp farkles!
That's a lot of bling, that is. Too bad the zinc process isn't pink.
when do we get to see it all installed in that spotless engine bay?
It’s all slowly been going back together. I’m leaving tomorrow for CMCC in NY and won’t be back til Sunday so not much will get done. My brothers and son aren’t going to be doing much on the truck without me there. They know better 😂🤣
Nothing crazy exciting here. Wanted to get the valve cover cleaned. Sand blasting is the absolute worst thing you could do. I was going to have it hot tanked but I talked to my plater and he said he would take care of it. He put in in the acid tank which striped away all hydrocarbons and make it look much better. He also ran it in chem film to protect/primer it before final paint. The chem film process looks very cool on machined parts. Not so much on cast aluminum 😜
But paint will be better.
Just some pics of the pieces I picked up at the platers just now.
-MAF bracket and bolts
- Radiator mounts
- EGR modulator and bolt
- Throttle cable standoff and bolt
- Air cleaner and tuna can clips
- Main harness firewall clip and bolt
- Forgot which bracket that is 🤔
- Engine lift bracket and bolts
- Power steering brackets and screw
- Air cleaner wing nut (I didn’t mean to do that one but meh)
OK, this thread is getting dumb :flipoff2:
