ARCHIVE Wits' End- If turbo isn't for you, what about going diesel? (4 Viewers)
Question: is the GM/SBC NV4500 the same thing as the cummins NV4500? So could this adapter assist with a 5-speed V-8 swap as well? I'm pretty sure I knew the answer to this question back in my 60 days... 🤔
It is basically the same transmission. The GM and Dodge have different bell-housings and tail housings, and differently sized input and output shafts. But in theory, yes, you could use this adapter plate for a GM swap. You would need a GM bellhousing and input shaft, with a Dodge 4WD tailhousing, and the Wits' End machined 2WD output shaft to work with the Toyota transfer case. That shouldn't be that big of a deal since you have to rebuild the NV4500 anyway to install the Wits' End output shaft.
Hope this helps.
Wasnt the Dodge the one that had synchros on first gear, at least for a few of the earlier years?
All forward drive gears were fully synchronized on both Dodge and GM. The early Dodge NV4500s offered synchronized reverse.
Early GM models also had a lower 6.34 first gear. The GM input shaft from a 6.34:1 early transmission will not fit the Dodge transmissions.
NV4500 Transmission | Advance Adapters
Can you register it in CA with a diesel swap?
Short answer is "not correctly". Folks have successfully registered their trucks with these in them, but any engine swap in CA is supposed to go through the CA BAR for inspection and stickering. The law states the engine has to come from the same "class" of vehicle. The 6bt only ever came in vehicles designated as medium or heavy duty. CA defines the '80 as a light duty vehicle.
This is as of right now, no idea what the case will be tomorrow. This also doesnt prevent you from buying an out-of-state truck (not in CA's system) converting it and getting it retitled in the other state and THEN importing it via the DMV or AAA.
I’ve discussed this with the SEMA shop. It’s doable on my side by developing an engine swap kit and getting that CARB certified. All doable but I am definitely NOT the one to do it. I’ve spent so much time and money on the 1FZ turbo that I don’t see myself doing it again for these.
Can’t wait to see final product. Been wanting 6bt for 80 but horror stories on other kit kept me away. Only bad thing is I don’t want to ditch h151 behind my carb 1fz
My SC’d 1FZ was pretty happy in snow around Mammoth and Tahoe
mine too sideways backwards almost upside down all good baby
Here you go folks. I have a couple things to still gather but otherwise everything will be ready to go by next week. Just threw it up on the site and I am now INCLUDING all of the necessary hardware and some Loctite ;)
Boom!!! Ordered and paid!
I really appreciate you tackling this project, Joey. It’s so nice to have a vendor that develops high quality products (and actually delivers them)!
whats the difference in length of a442 and nv4500 as well as 6bt and 1fz?
They have nearly identical dimensions. The 6BT is slightly taller with the intake horn. And slightly longer (the Cummins A/C pulley and oil fill tube sit in about the same plane as the Toyota mechanical fan).
The 6BT/NV4500 in the video also has an Advance Adapters output housing on the NV4500, not a Dodge 4WD extension housing (which is the housing you would use for the Wits' End kit). But the dimensions of the transmissions are similar as well.
I'm sorry, I don't know the weight difference. I assume the 6BT is heavier than the 1FZ-FE (because it's all cast-iron), and that the NV4500 is lighter than the Toyota auto. My vague recollection was that the 6BT/NV4500 was about 300 lbs heavier in total, but that includes the turbo, intercooler, piping, and cast-iron head from the 6BT setup. About the same weight difference as a heavy-duty bumper and winch...but with twice as much torque ;)
