mingles
GOLD Star
I have often read on MUD, and I believe it is recommended in the FSM, that to pull the axles on an E-locked truck the locker should be in the locked position. This is to make it possible to reinsert the axles without difficulty upon reassembly. It is one of those steps that just I did because it was recommended, without knowing why.
Now I know why. Inquiring minds read on …
When you see the locker in a disassembled diff, it becomes pretty evident the rationale for this procedure. When the locker is unlocked, the locking collar just “floats” on the axle shaft, with the shaft holding the collar in alignment with the differential, ready to slide into the locked position when given the signal to. With the shafts removed, in an unlocked position, that locking collar that was “floating” drops out of alignment with the rest of the differential. The shafts will come out easy in an unlocked state, but when you try to reinsert them they will slide in only to where they hit the out-of-alignment locking collar. In the locked position, the locking collar has dogs that mesh with matching dogs on the differential and is held in place whether the axles are inserted or not.
And because we all like pictures …
