I know a lot of people are running this including myself. Does anyone know of a drag link or tie rod that has right hand threads and fits the fj60 pitman arm? When i intially did my steering swap i was in a time crunch so i cobbled something together with what i had available. I made a custom relay rod with a bj70 drag link on the pitman arm end however what i ran into was the correct tie rod for the other end of the relay rod also had left hand threads. I temporarily installed a different tie rod on this end (with right hand threads) but was not happy with it because the shank is not long enough and doesnt provide enough thread engagement into the factory fj40 pass tie rod end. At this point i am replacing all of my tie rods and wanted to properly take care of this. I have a new tie rod for the lower end of the relay rod (proper shank length) and will make another custom relay rod so, i am in search of something that will fit the fj60 pitman arm that has RIGHT hand threads. I know it will probably have 19, 21, or 23mm threads which i am fine with. I just need the correct taper for and correct thread direction.
