HI Guys, My 1976 FJ40 has 16 " welded wheels with disk brakes.
Im looking for wheel and tire suggestions.
Dear Sir: I am living with and working with the same or similar problem. I am looking for a 16 X 6" wheel for use with a 235/85R16 tire. So far, the wheels I have found are "trailer-type" wheels with a "zero offset." Do you know if these will work in the back of a stock FJ/BJ 40?Which 16-inch wheels are you running? I can't tell from the photo. On my '86 FJ60 I'm running the 70-Series 16-inch wheels with BFG LT235/85R16 ATs. They are about 32 inches tall. I like the tall skinny look, and it suits the type of driving I do. I think that tire size is about the maximum you could go on an FJ40 without a lift. The BFG 30X9.50R15 ATs look good on my pretty much stock '76 FJ40, a little taller than the original tire size.
I'm pretty sure that you need wheels with some offset, at least -0.25" IIRC. I finally bit the bullet and bought the new 70-Series wheels.Dear Sir: I am living with and working with the same or similar problem. I am looking for a 16 X 6" wheel for use with a 235/85R16 tire. So far, the wheels I have found are "trailer-type" wheels with a "zero offset." Do you know if these will work in the back of a stock FJ/BJ 40?
Thank you for your input and insight. I will take this into consideration; however, I received input from a Canadian fellow who has "zero offset" 16 X 6" trailer wheels mounted on his BJ42 with 7:50 X16 tires, and he says that they fit/work all right, so it is a problem as to how to measure/make sure - one way or the other.I'm pretty sure that you need wheels with some offset, at least -0.25" IIRC. I finally bit the bullet and bought the new 70-Series wheels.
