Builds What's a Parts Guy to Do?? (1 Viewer)
Yeah...where's the showroom for this Onur?
Hey...hot metal and paint don't mix so well...I know you have access to plenty of cardboard :D
:lol:
And even more parts Dan:
New hood bumpers:
Clutch inspection cover with new gasket material. The OEM gasket kit for the cover is discontinued so you kinda have to improvise. I used OEM air filter housing gasket material, cut it in pieces, followed to the best of my ability the schematic and use FIPG to hold in place. It was a bit sloppy, but it worked. Also, used new bolts to install into place as well.
Installed new speedo gear and sleeve:
Inspection cover installed:
THAT'S WHAT SHE SAID X 10000000000000000000000000000000000000000000
I think it's too pretty to put into a truck. It should be on display in a museum.
Cover your tranny shifter hole or yer going to drop something in there you can't get out.
That is looking really good from here.
Back a page I see this:
I'm gonna fly out there and drop in a sheet metal screw if you don't stuff a rag in there today. I inverted a plastic cup on mine and duct taped it in place.
img_7449-jpg.1029141
And, do you have a date picked yet for the install?
Bummer, I had a perfect inspection cover that peeled right off with no tears, completely reusable. I threw it away when I blasted/painted the cover. :(
Does anyone else sense some "mission creep"?
:lol:
The core support, front panel, the crossmember, and top support are all going to my body shop to have cleaned and sprayed new.
Axle housing is looking a little rough. Better start working on those too while you're at it.
