Received the power steering rebuild kit from @beno I'll be removing and rebuilding the PS pump with full documentation coming soon.
Looks great 78fj40mg! I have wanted to do this too but was wondering if the LED's behave the same as the OEM bulbs. Turn signals have enough resistance to trip the flasher relay and tailight/brakelights have 2 different levels of brightness? Thanks!![]()
If if matters I vote yes on rear discCleaned the frame out, made a couple of frame repairs and swapped the small for large eye shackle hangers, painted the frame, broke down the axles and painted... Should I go rear disc??
JView attachment 1077643 View attachment 1077644 View attachment 1077645 View attachment 1077646 View attachment 1077647
If if matters I vote yes on rear disc![]()
OK I will twist your arm.you have to put rear disc on because if you dont in six months you will be kicking yourself for not doing itFor the price of new quality drum components... Might as well RIGHT?
J
... Should I go rear disc??![]()
Going from my experience with rear disc, a profound YES! The only drawback would be if that precludes using stock rear drum E-brakes (I don't remember what axle you are using). If so, I'd still go disc and find a different way to mount E-brakes.
Don
Don,
It has a 68 factory rear. Swapping in a '86 FJ60 power train. So was thinking of going with aftermarket rear discs with a built in parking brake. IIRC the eldorado calipers. I've read both sides to these. Some guys say they work great others say they are not worth the extra money. This rig will more or less be a light duty rig, no rough wheeling and on pavement 95% of the time.
I just need to see if the kits will work on the earlier axles.
J
I swapped to rear discs using Monte Carlo calipers (no emergency brakes). The truck stops incredibly well, so from that standpoint, I'd say it's worth the effort.
The lack of a driveshaft parking brake in the 60 driveline makes it trickier. I've hear the el dorado emergency brake setup rigged up to a 40 is mediocre at best, but then again...so is the driveshaft drum.
