What have you done to your Land Cruiser this week? (38 Viewers)
Getting there. Now to run a brake switch wire to the middle bulbs
Yesterday I took apart my steering wheel, pulled it, removed my blinker switch, and cleaned all of the contacts. The main one that needed work was the high beams. I cleaned contacts, then re-tensioned the contacts, greased all moving parts with a small tube of dielectric grease I had. Now the high beams work. I've still got one turn signal that comes on and doesn't blink. I'm going to look into that today. I may try another blinker/flasher unit.
I think I also have a marker light out.
Then:
Leaving on Sunday, back up to the wilderness to wheel the snot out of it.
Well since Saturday to Tuesday I've been working on the back wheel bearings and brakes, then suddenly when I was ready to ride it won't started. So the problem was the alternator and voltage regulator
But now I'm looking the wiper motors but I don't find them, I don't remember where I left them. I'm afraid that I have to buy them if someone knows about some replacements I'll be thankful. It's a Fj40 1963 corrugated
Then:
Make sure you check all the bulbs and grounds on your marker lights/turn signals before replacing the flasher relay - especially if only one side doesn’t blink.
I ended up misdescribing the problem
The blinker didn't turn on, and the 2 rear bulbs did, but didn't blink due to having too light a load.
Once I cleaned the ground for the front left blinker, now it turns on, and blinks. Both sides, same speed too. I also tightened a ground on the right rear marker light and now I've got a full set of working markers.
Don't want to get a ticket.
What a difference from the east coast…you have to really hunt for something this beautiful. It’s not just “along the trail”
Broke Mr. Myagi out for a little spring time exploring after an oil change, water pump replacement and general lube session.
No more zip ties anymore. (at least not in this spot) Replaced the short piece of flex rubber heater duct inside the cab with an NOS OEM one thanks to @hyhpe. The factory OEM duct is a much better fit than the aftermarket one that required zip ties to secure it in place.
Also, replaced braided fuel line and barb connections with a nice clear fuel line and fittings kit from Justin at Redline. Gotta love starting out the day by lying flat on your back while gasoline runs down your arm and into your face while trying to get the new fuel line onto the the hardline on the frame rail. After a prolonged period of no-go while gasoline continued to puddle on the floor I used a heat gun to soften the new fuel line just enough to get it to slide over the fitting. (of course, I realize that Toyota stopped using the clear plastic fuel line after 1969, but I think that it just goes well with the glass bowl filter.
Waiting on deck: changing out the Old Man Emu shocks and damper for Dobinsons.
I have one from Cruiser Corps that I’d be happy to give you. Not sure of what model years it fits. It’s is 1970.
That’s awesome. I’ve looked at that hose on their site a few times but overall I haven’t been overly impressed by the parts and pieces I’ve gotten from them.
Maybe if it passed through your hands it’s better?
The outlet on my box is ovoid. Let me look into it and I’ll PM you.
Thanks GB
