Cuppa cruisers.
Make sure you check all the bulbs and grounds on your marker lights/turn signals before replacing the flasher relay - especially if only one side doesn’t blink.Yesterday I took apart my steering wheel, pulled it, removed my blinker switch, and cleaned all of the contacts. The main one that needed work was the high beams. I cleaned contacts, then re-tensioned the contacts, greased all moving parts with a small tube of dielectric grease I had. Now the high beams work. I've still got one turn signal that comes on and doesn't blink. I'm going to look into that today. I may try another blinker/flasher unit.
I think I also have a marker light out.
Then:
Leaving on Sunday, back up to the wilderness to wheel the snot out of it.
I ended up misdescribing the problemMake sure you check all the bulbs and grounds on your marker lights/turn signals before replacing the flasher relay - especially if only one side doesn’t blink.
Thank you. I'm getting antsy to drive it. It's only been five weeks since I pulled it apart, but I miss kicking around in her.Man alive. That is a beautiful engine bay.
I sure need to source this defrost duct for my driver side.No more zip ties anymore. (at least not in this spot) Replaced the short piece of flex rubber heater duct inside the cab with an NOS OEM one thanks to @hyhpe. The factory OEM duct is a much better fit than the aftermarket one that required zip ties to secure it in place.
That’s awesome. I’ve looked at that hose on their site a few times but overall I haven’t been overly impressed by the parts and pieces I’ve gotten from them.I have one from Cruiser Corps that I’d be happy to give you. Not sure of what model years it fits. It’s is 1970.
