What have you done to your Land Cruiser this week? (14 Viewers)
Stock is beautiful! ;)
...great rig, congrats!
Normally I agree, but with the bull bar up front and the customer rear bumper and tire carrier, I think an after market front bumper will fit his style nicely. Tuck that bumper away for the future if you ever decide to return to stock👍👍
Painted the windshield hooks. Started cleaning the paint and applying penetrol. Also continued chasing shorts within the signals.
Bastardized my '76 FJ40 some more by, at least temporarily, swapping out my FJ60 coil/igniter with a Tercel coil/igniter. I had to fabricate a temporary jumper - the connector at the coil/igniter and the connector at the FJ60 distributor are the same gender. I'll correct that by replacing the coil/igniter lead with a new lead of the correct length (longer than the Tercel lead), using some new shielded cable I bought off eBay and a new connector I got from @ToyotaMatt. It fired right up and runs great.
BTW, the '76 now sports two Tercel parts - a power steering pump and the coil/igniter.
Fabricated and installed a new lead from the '82 Tercel igniter to the FJ60 distributor in my '76 FJ40 a few weeks ago. We flat towed the FJ40 to the first annual Land Cruiser Unite event at MERUS Adventure Park SE of Amarillo. The FJ40 did great with this set-up. This expands the list of alternative igniters in @Coolerman's Dizzy FAQ to include Part Numbers 89620-16050 (igniter) 19070-15080 (coil/igniter assembly) - 8/79 through 7/82 Tercel with the 3A-C engine.
Fabricated and installed a new lead from the '82 Tercel igniter to the FJ60 distributor in my '76 FJ40 a few weeks ago. We flat towed the FJ40 to the first annual Land Cruiser Unite event at MERUS Adventure Park SE of Amarillo. The FJ40 did great with this set-up. This expands the list of alternative igniters in the DizzyFAQ to include Part Numbers 89620-16050 (igniter) 19070-15080 (coil/igniter assembly) - 8/79 through 7/82.
These are the items that will sideline our rigs. Well done. The other TEQ(early supra…) owners will appreciate this as well.
Do the Tercel wire colors match up with the OE ones in the LC?
IIRC, the stock '76 igniter is a points-type, the spark plug gap would be 1mm. The FJ60 distributor and the Tercel igniter / coil puts you fully into electronic ignition, the later FJ60 2F uses a different plug and a wider gap for the hotter spark, right?
To be honest, I never thought about that. Something for me to look into.
I run the positive (+) wire from the ignition switch to the coil positive (+) terminal, along with the wire to the idle solenoid. And I run the ground wire to one of the coil bracket mounting bolts to ensure a good ground. The Tercel igniter has red and white wires that connect to the corresponding red and white wires to the FJ60 distributor's signal generator. I'm pretty sure the Tercel igniter can also be used with the 9/77 through 8/80 electronic distributors.
The SKUNK WORKS Lab 🧪 has doubled down on all this OEM Yazaki japan JIS Jazz …
