What have you done to your Land Cruiser this week? (52 Viewers)
I had Wheel Vintiques 16 inch wheels on already but I had a custom backspace (3.5") which they do by reversing the rim. Kinda nit picky but it drove me nuts. Went with standard 16x7 with 4" back space and they seem pretty good. Have to roll the clamps up on the relay rod and maybe move the stop a tiny bit (but doubt it). Quick powder coat in RAL 7037 and swap tires. Looks more betterer now. Still working on the hub cap adapters but I think it will work.
How did you attach the hubcaps? What do you mean when you say they “reversed the rim?” Any shots of that? Just curious because I’ve thought of going this route.
The center is welded onto the rim backwards. It is the only way they can get the Cruiser 3.5" backspace with the 12 series wheel. It really doesn't look so bad. Just kind of a smooth dish look rather than the "steps" that the original 40 wheel has. I will attach a picture.
The hubcaps are an adapted factory cap that I am working on. Not sure If i will be selling them or not but basically it involves cutting the back of a factory hubcap and tig welding on a ring that fits the Wheel Vintiques wheel. The drawback so far is that I can't get the edge of the factory cap flush with the wheel center face. You actually can hardly see it looking at it, but it is an issue I suppose. I will try to post up pictures when I get home so at least others can copy the idea if they want.
I will be selling my nearly new take offs in 16x7 with the 3.5" backspace (4 of them), powder coated RAL 7037 grey (nice factory color match) as soon as I clean em up and wrap em up. I will post in the classifieds when they are ready to roll (no pun intended).
Message me regarding the wheels you'll be selling. Ed
Picture would be cool - as I had thought about grabbing a set of the series 12 rims in a custom backspace (in fact I have a quote from Wheel Vintiques from sometime last year, I just never pulled the trigger).
You certainly don't notice the gap from 5-6 feet away in the picture above.
I don't have a great picture on my phone but this one from the other day kinda shows the reversed wheel. I'll do more pictures later today if I get home before stupid late again.
Thanks! I kind of see what you're saying.
Also tried Wheel Vintiques series 12 wheels. Ordered 15 x 10 and specified a 3 1/2" backspace. When they arrived I tried them and found their backspace was more like 3 3/4". When I called I was told that 3 1/2" was not possible exactly so I returned them. The refund took two weeks and two phone calls and they still stiffed me $10 on the return.
I’d take my roof off far more frequently with that around... :D
Drove it!
Shakedown runs and 350 break in continue - I put about 50 miles on it tonight, and found a gravel lot where I could make sure the transfercase (rebuilt by me with LOTS of help from @orangefj45) worked as it should.
Everything is running well, but tonight I found something odd -
I get a small fluctuation in amperage, which in turn creates a small (30rpm) idle fluctuation. Normally, idle fluctuates between ~710-740 rpm. I thought that was just the nature of a carbureted engine. What is REALLY odd is that the more electrical load I put on the truck, the BETTER the idle gets. Idle drops (to be expected) under load, but if I have lights, wipers, and fan all running, the truck idles perfectly at 600rpm. Zero (I mean zero) fluctuation or surge.
Alternator issue? Distributor issue? I’ve seen idles hey WORSE when accespries sap power from the distributor - this is the first time I’ve seen it get better...
Tomorrow I’ll unhook the alternator and see if my idle stabilizes without it. Any other thoughts of what might cause something like this?
Seriously, can you swing by my house this evening?
I'd look pretty dumb driving down the side of the highway all the way to GA just for some beer!
What the heck
@dogfishlake, if the price is right, and they fit a 17" wheel vinteque I may be interested in a set of those hubcaps
When I get it figured out, I will post up how to do it regardless of whether I'm selling them or not just for the diy'er.
Drove it!
I'm an alternator moron for the most part but doesn't the voltage regulator kick the alt output up under high demand? So maybe your alternator or regulator is failing or marginal when on low demand?
A guess
A guess
I was thinking maybe something like that. Just seems like the opposite of what SHOULD be happening with a bad regulator. I'll probably run it a bit with the alternator unhooked tomorrow to see if it smooths out.
