Took the old girl camping at Gold Lake this week. We putzed around a lot and actually did some light wheeling in the -40.
So what's going back in?
My '84 FJ60 is due for a new clutch after 182,000 relatively hard miles. The rear main seal is due for replacement, the steel drain pan works well to contain. The amount of oil leaking picked up quite a bit after the fuel pump failed and contaminated/thinned the oil with gasoline. Less volume now after an oil change. Good luck with the cleaning, a lot of grease/mud/grime on there.Just a new clutch and a cleaned up trans and transfer case.
My clutch was hammered and the pilot bearing was in pieces.
It had a heavy shudder when I released the clutch I figured was a burned flywheel but after pulling it down it was all of the above. Hopefully the PO didn’t drive it too much like that so the tranny output bearing didn’t suffer too long.
Tearing down front axle. To swap out the 3rd for some new stuff
/QUOTE]
Going fine spline axels?
Heath Grey
Aka spectramaster ls 183...![]()
Built some heat shields to try and get my floor below 140 degrees. Not sure how much good they’ll do with the V8 right in front of me but it was a fun side project.
Cool- thanks!
Who carries it?
that's sucky i really was planning on using that and oh ya tried to install my PTO drive shaft i guess i should of done that as i was stabbing the tranny cant seem to get it to slide in guess i will have to slide the tranny back to fit it anybody else have a better idea
i also put the brace on the drivers side of my radiator and tightened the bottom studs Went topless. No pictures of me topless, that ain't pretty. The 40 looks downright sexy topless.
@dogfishlake Have you put your new hinges on yet? I meant to ask you last weekend at the get together thing, but there were so many mud names to decipher while learning real names...
