That’s the EASY button…. I’ve seen them on TV…
The horn....I can't seem to find the rest to make the horn button work ....What does the red button do?
Don't forget to check the horn relay. Mine must have been shorted and it was causing my fuses to blow. Once I disconnected it (and ultimately replaced it) all my electrical troubles went away.Shorts are the worst. I’ve narrowed it down to the hazard switch and/ or the power from the panel to the hazard switch. So far I’ve tried:
-disconnecting the wiper motor (blew the fuse),
-disconnecting the turn signal switch (still blew the fuse),
-hazard switch (didn’t blow the fuse).
-testing the hazard switch (passed),
-and now I’ve rigged up a test light from the panel to see if it will light up for me on a drive.
I think I’m going to de-pin the power feeding the hazard switch connector and extend it to the turn signal switch to confirm if it is the hazard switch or the wire powering the hazard switch.
It will release this section of roof, then engage and fire the passenger side ejector seat.What does the red button do?
More engine assembly. It’s like man jewelry.
YesHaven't done it yet, but want to ask, can the front transfer case output shaft seal be replaced without dropping the transmission? I replaced the rear when I did the parking brake. Now the front is leaking.
The rocker arms didn’t have any bushings, it’s a single cast piece. Here’s a picJust wondering if you re-bushed the rocker arms? The OE bushings don't seem to be available any longer.
Bench bleeder, very nice!
Spend a little time now to save headaches later.Bench bleeder, very nice!
Critical step on master cylinders...
I love the satin black finish on thisPut a refurbished heater blower motor in the Karma Cruiser. I picked this up three years ago from forum member @Tanker120 with plans to put it in the 65swb45. Didn’t realize until I had the two units side by side that it wasn’t period correct for the ‘65. But it was a perfect match for the one in the ‘69. AND I discovered on my desert adventure at the end of February that the blower motor in the Karma Cruiser wasn’t working. So out it came!View attachment 4110815View attachment 4110816
Now it’s the second shiniest thing in the truck. First is still the restored wiper motor from @thundermcawesum, which got a heck of a workout on the same trip.
