What have you done to your Land Cruiser this week?
Let me tell you about the most pain in the ass job to do. I decided to hot rivet the rear frame rail to the cross members rather than simply bolting them in. Some of you might have had great success, so please share your experience with details. Here is mine....
1. finding and using the right backing buck was a huge pain. I used a combonation of the threaded jack style, old dolly that I carbided a divit in, 1.5" pipe filled with weld and then welded on a small section of 1" square tubing. On flat surfaces, each of them worked fine. However, the sections that were a tight fit and had other riviets on the opposite side were the bigget head ache. I could not get enough clamping force on the buck to hold down the backing buck. The vibration from the air hammer cause the buck to come off and ruin several rivets. I would then have to grind off the rivet and start all over
2. Air hammer was another issue. All I had was my long barrel air hammer which was way too powerfull and always knocked the backing buck off. I ordered a short throw barrel on Amazon
3. Hot rivet bit. My first attempt was to make a bit to go into the air hammer by taking a 1" carbide bit to a standard pneumatic hammer. This worked well, but didnt get the desired "factory" shape after numerous modifications. I then decided to buy one online. This one gave me the desired dome shape, but dammaged the frame from the edges. I then took it to the lathe to machine a few thousands off and softened the edge. This worked well, but the bit would occasionally bounce off and ruin the finish. At this time I was completely over it.
After several attempts I finally gave up and decided to simply bolt the rivet and try to dome the hex head with heating it up and using the air hammer. I will touch it up with a bit of shaping with the air grinder.
Again, if you have detailed instructions to share on this process, please share.
@Aloha Jen. I’ve been hearing so much about flooding…has this affect you and yours? Hope all is good
Cleaned one up and swapped them out.
Time to track down the short in the hazard/ turn signal circuit.
Bonus shot of my daughter rocking a Land Cruiser t shirt during cleanup.
Thanks for asking, it’s crazy seeing my little country town on the national news. Our area definitely experienced the worst of the flooding. Fortunately, my family and I are safe with very minor flooding of our garage (didn’t reach the drywall/studs in the garage). But, our house sits on a little high spot, my neighbors just down the road had catastrophic flooding and lost everything. So sad, a good portion of my little town was underwater and was really negatively affected in terms of property loss and displacement. It will be a long cleanup and rebuild process.
My house is just above the top right corner of this photo.
Maybe my tech video will help with Hazard circuit issue.
That’s a great video. I wish it had been around when I was trying to figure out that exact problem on my ‘67 a few years ago!
Unfortunately, this one is a bit different. My turn signals work just fine, and the wipers do, too. But the fuse ends up blown by the end of the trip. Not while I’m purposely drawing any power (not while in use), just randomly while I’m driving along so that when I go to use my turn signal, it won’t work.
Shorts are frustrating to track down. The rear harness gets a lot of exposure. Disconnect the rear harness from cowl harness at the firewall and drive around. If no blown fuse you’ve isolated it to rear.
Shorts are the worst. I’ve narrowed it down to the hazard switch and/ or the power from the panel to the hazard switch. So far I’ve tried:
-disconnecting the wiper motor (blew the fuse),
-disconnecting the turn signal switch (still blew the fuse),
-hazard switch (didn’t blow the fuse).
-testing the hazard switch (passed),
-and now I’ve rigged up a test light from the panel to see if it will light up for me on a drive.
I think I’m going to de-pin the power feeding the hazard switch connector and extend it to the turn signal switch to confirm if it is the hazard switch or the wire powering the hazard switch.
