What have you done to your 200 Series this week? (32 Viewers)
It's not too bad, but is tedious, I used about 4 quarts of fluid. I wedged my phone (w flashlight on) behind the AHC tank so I could see the fluid level. I bled each line until there was bright pink fluid coming out, which involved several drops/rises on each accumulator. Also, I was getting overflow when I tried to fill the tank through the hose, so I just removed the hose (w white cap) and pumped fluid directly into the tank.
About to do this too!
Installed and wired Baja Designs Squadron-R sports on the Dobinsons bullbar. Installing and wiring LED camp lights on TT rear swingout.
Hit 50k on the way to Lake Powell.
:crybaby::crybaby::crybaby::crybaby: She's growing up!
Who did your chrome delete? I’m in OC. Thanks brah!
I got it done at SD Wrap while AutoArmour was doing the PPF. They share a building (Elite Finish is in there too) in San Diego (Miramar, specifically).
Well I'm proud to say the very first mod I've done to the LC is the rear exit mod.:D Thought I'd start with something simple. Thanks to @cruiseroutfit for the quick ship on the backordered part!
High current power / winch disconnect.
Now to make some really expensive jumper cables...
I hadn't done the much needed paint correction since I got the truck.
It still has some trail pin striping that I couldn't cut out, but I was able to get all the smaller scratches and swirls gone.
I've had this bookmarked since 2008, have you seen it?
HOW TO: World's Most Expensive Jumper Cables
Mike
Yep! Always meant to to that on the 100 but never got around to it. Then I had a friend who had his winch self-energize in the middle of the night and nearly burn his house down and I decided that having a positive disconnect between the winch and the batt was a really good idea. Additionally, with this install, anyone can immediately kill a runaway winch in the field just by pulling out the cable.
More info please
Added BP-51's and SPC UCA's...and Friday 5 new tires. Going with the
Nitto Ridge Grappler LT295 /70 R18's.
What wheels/spacers? I have a feeling that's going to rub pretty bad. I have the same suspension and those tires in 285/70/18 on stock wheels, and I can't imagine going any bigger without running into issues. I test fitted that exact tire on mine with some Tundra wheels, and there was no way it was going to work.
