What have you done to your 100 Series this week? (30 Viewers)
The tubbing for 37s will continue until morale improves... I think there is room for 38s... one :banana: job
Stock suspension and no lift.
All 8 coil packs are cracked, O2 Sensor going out (P0420), and 8 spark plugs :bang::confused:
Popping $800+ in a week is not ideal, but neither is getting 6.6MPG. I'm hoping that I'm onto something here.
That’s how a few of mine looked when I was replacing my plugs last year. I put them back in and it’s been running fine since. I know where to start looking if problems start though.
I think Denso is the OEM coil - those should be cheaper.
For your calipers, did you go aftermarket? Bleeding, did you go old school two person method, or did you use tech stream? I ask because I think one of my rear calipers is sticking, and I want to tackle this as soon as possible.
Aftermarket calipers from TRQ/1a auto. DOT-3 brake fluid.
Old school wife in the driver’s seat, crack, pump, close, repeat.
I must say, i'm not a huge fan of the LEXUS grille, but with the bumper and hoops on it makes the whole look work together.
Yeah, I am still on the fence on the grill and may eventually switch back to my OEM lol. I do agree, it does look better when it is not the highlight of the front end.
Thanks for the before and after... I think mine is looking more like before than after. Guess I'll have to keep an eye on it. I assume "after" is at idle?
Yes, the image was taken at idle. I have a 1999 and recommend removing the alternator from the top by unbolting the steering pump (not removing it, keep it connected), air box, and top vertical radiator hose. Don't wait too long; it's a simple enough job and is better than getting stranded. If you are under 14V at idle with a basic voltmeter, its time. I waited too long and ended up pushing her home part way, LOL.
