What have you done to your 100 Series this week? (47 Viewers)
Replaced Front Speakers. I'd say it was about time. Rears are next.
Little plasti dip don't hurt no one :) I sort of want that alpha garage grille.. but the reviews are kind of all over the place..
295/70R18 installed today. Did the pinch weld mod but haven’t messed w/ washer fluid cover or reformed the plastic in front of the pinch weld. No rubbing that I can feel/hear or see since driving ~30 miles day 1. Will keep an eye. For sure noticeably taller, thankfully. In high mode it looks awesome. Will likely adjust sensors once I have techstream up and running. Also have AHC fluid in route but taking forever to arrive. Ride is still great, so the posts I’ve read make sense to me now. A bit firmer but a good firm. Seems like the perfect size for the LX. I had 285/65R18 on my LC and they did seem a hair small.
Oh, finally finished the ARB bumper install too. That took a long time w/ just me and also having a newborn.
Lots of other little things I’ve done since purchasing last month. More to come. So happy to be back in a 100.
IF those are the cheap Chinese corners, I recommend you spray them with a clear UV protection paint. Otherwise they will be yellow and foggy in 18 months. Ask me how I know...
How do you know so much? Pics or it didn't happen. Please, sir.
Spent some time trying to figure out why my rear passenger side corner is sitting 3/8” higher. Ironman springs are definitely seated correctly so I’m wondering if one side has a stiffer spring rate for fuel tank or whatever?
From the Ironman FAQ page:
Refer to completed installation form to measure and compare with new ride height. If a vehicle is leaning down on one corner, firstly ensure the vehicle is on level ground and then assess the weight distribution to ensure even placement of load and accessories.
Many vehicle models exhibit an uneven weight distribution from factory, Ironman 4×4 adjust the spring height accordingly to level the vehicle.
Check if springs are designated for Drivers Side (D/S) or Passengers Side (N/S) and ensure they are installed to the correct location. Typically the taller coils should be fitted to the heavier side of the vehicle.
Yep, level ground and are in the corresponding side per the printed placement on the coils.
The RR corner is the lightest so that makes sense to me. Put a 10mm spacer on the LR and call it good.
Who makes coil spacers like that? Ironman only sells a 15 and 30 mm spacer.
