I always figured people put spacers on all 4 wheels.....Is it common to just do the front?
You have to do the front minimum with the rock warriors.
I plan to order a pair for the rear I just haven’t done it yet.
CV Boots on both sides apparently didn't like the Eibach Lift in front set at 21.25" even with the Slee Diff Drop, throwing grease. Seemed to be the clamps when inspecting, hope the recommended McMaster clamps do the job. I left them just finger and thumb tight with a ratchet screw driver, needed a little more tightening and I am scared to overtighten them. I will check through the week, but seems very much improved.
Aren’t front spacers only necessary to run the RW center caps? Or is it necessary for wheel clearance?
Unsure if you added more about this project, but I am in the same PNW boat and this thread is long.For those of you up here in the PNW with me, you'll be able to relate to the recent fun of the "atmospheric river" we've been experiencing, AKA days on end of dumping rain. I noticed a drip to the interior from both front corners of my sunroof that wasn't the seal to the truck body. It turned out to be the inner seal bonded to the glass itself. Water gets between the inner rubber and the glass and runs down into the front plastic bezel piece. Once enough water has built up there, it drips out the seam where the front and side interior trim bezels meet.
I was all ready to pull the trigger on a new glass as you can't get this rubber separate, but it looks like Mr. T wants $750 MSRP for one now, ouch! I'm going to try a bit of sealant first and see if that'll be enough to do it. If not, it looks like an early xmas gift for the cruiser.
Separation was the worst at the front center where the two pieces of this rubber meet. My driveway is level and with the forward rake of the suspension, this is always sitting underwater whenever it rains.
The rear join is just starting to separate, but not yet as bad as the front.
Unsure if you added more about this project, but I am in the same PNW boat and this thread is long.What caulk did you use and what was the outcome? Thanks!!
Is that a bullet hole?Getting all my valuable junk out so I can take it to get an estimate. Hit the steering wheel airbag. Provably going to total it.
Wannabes posting up in my neighborhood, not using prudent aim at their intended target. Kids these days, gotta teach them everything!
Yup. Sure is.Is that a bullet hole?
“ORV…bullet holes…bullet holes?”Yup. Sure is.
That’s called character.Yup. Sure is.
what part of Seattle are you in? I'm up in Shoreline if you need any help.Knuckle cleanup and overhaul, new bearings and races, new UCAs, new LBJs, sway bar bushings, front diff bushings, diff drop, new torsion bars and shocks... Hopefully it will be drivable by next spring and I won't be bankrupt
I'm in Greenwood too, so happy to help as well!what part of Seattle are you in? I'm up in Shoreline if you need any help.
