What have you done to your 100 Series this week? (25 Viewers)
Had another busy week:
  • Raised the spare tire with some spacers.
  • Replaced four door lock motors with motors from Ebay.
  • Disassembled and repaired the driver side master window switch assembly with some JB Weld, but I found the bulb for the auto switch out so I need to find a replacement for that.
  • Started replacing the steering rack bushings when it started to hail. Found one of the bushings melted with black gunk all over the crossmember so I assume the oil/power steering ATF leaks over the years caused it to disintegrate.
  • And finally pulled apart one of the 2nd row seats to figure out why the rear seat lock was not extending. Found one of the leg stays broken and another special surprise from the previous owner...
Im going to go out on limb here and say thats not rock salt that the PO was carrying around in case if a sudden snow storm...
Repacked wheel bearings and did the diff and t-case oils again and lubed the driveshafts. Last time I used cheap stuff this time I went with synthetic Lucas and Red n Tacky for the wheel bearings. I noticed water in my passenger side drive hub from water crossings this year so I sealed with RTV this time.
Lucas Red N Tacky: https://amzn.to/2UbrHZo
Lucas Synthetic 75w-90: https://amzn.to/2Ih4hPA
Thats baller. You got a link for that?
Is that a rock of meth or crack? Can't tell lmao...
Bled the AHC system after 5k of ownership. Squared away the front shock pressures with techstream as well. Rear are still reading slightly high but haven't tried to unplug the temp sensor yet. Drivers side torsion bar adjuster was rusted, needed a real impact to break it loose.
160k now and its lexus service records say the ahc system was never flushed. Threads on here say the used hydraulic fluid would be green but my fluid was black and smelled like fertilizer. The longest part of the flush was getting the old fluid out of the tank with this little 10ml syringe haha
As far as I know the AHC fluid should not come out green.
It's pretty gray and oil colored when it's new. Mine also smelled like horse poo when I flushed it.
well after the flush the system transitions from L--N--H much faster, i cant tell if the ride has improved or not. It didnt feel harsh before.
🤷‍♂️ idk, dark green... must of misread this first post
wherever you are i’ll take that baggie off your hands.
new wheels and tires arrived at the office.
Ehh you wouldn't want it. It was a bit moldy.
Don’t visit Mexico in that truck.
Yea, slightly concerning. Would not be fun to have a drug sniffing dog indicate on the car. Current plan is to slowly pull apart the interior and do a deep clean and make sure nothing else fell into any cracks.
I had a friend take his new to him Corvette to the police and asked them to have the dog check it out. They were happy for the training opportunity, and he had the piece of mind he wouldn’t get caught trying to explain it wasn’t his stash.
That's a fantastic idea.
had it inspected today and hope to have the title work/plates in the next day or so. 99 locked rear with fairly low miles. Runs great and clean interior. Unfortunately it originated in PA before I got it from the last owner in Charleston. Needless to say it’s getting a frame/suspension swap in the January timeframe. Should be interesting. Will become my DD.
Took the family loaded with gear to Idyllwild in the San Jacinto Mountains near Palm Springs, CA. The War Wagon rode great but it dropped into Low immediately with all the added weight.
Flushed the AHC fluid using the great instructions of this forum. It was easy but I did make a bit of a mess in the driveway.
I think the springs are TIRED after 250k miles. I’m thinking about going with the Kings. Pressures are high front and rear currently. I suspect that going with the Kings springs will drop the rear below spec, but I plan to add skids and sliders which should help.
Wife would kill me if I posted a pic with her in it, so I have none with the War Wagon in action.
Would be great if you could document some of that. I've got a crusty '02 LX that i'd seriously consider doing a frame/suspension swap on down the road, but have no idea what the cost would look like.
  • Back
