What have you done to your 100 Series this week? (55 Viewers)
What is the suspension / tire setup on your rig? It's beautiful!
Thanks!
Icon stage 1. Old Man EMU torsion's and 866's in the back. Duratrac 285/75. Its actually sagging in the back about 1". I have a single drawer, fridge and tailgate full of storage. Going to try the 863s.
Looks great!! What size ko2 are you running?
Last week, removed the running boards and added the really awesomely bright @Ramathorn15 Owl plug-and-play LX courtesy/puddle replacement and rock lights lights. This week, replaced the rear hatch lift supports, removed the rear mudflaps, and added the @LandCruiserPhil Mud Flap Eliminators - Land Cruiser Products - LCP Really transformed the look, awesome products guys!!View attachment 1447477 View attachment 1447493
That's a great looking truck. I hope to remove my running boards one day but they're necessary right now.
Ordered LCP rear mudflap delete. Feel like I should start a build thread.
Very strange as Rear AC was standard in 2000 and onward. Never seen this heater button in a US spec 2000 model year truck. The 98's and 99's had rear heat and the rear AC was optional in 1999.
Do you have the big red heat knob in the back of the center console for the rear passengers?
Do you have both Rear AC with controls and vents in the ceiling and rear heat? Never seen that. Maybe the truck is from Canada.
Great, hopefully I don't have some rare (read: $$$ to repair HVAC controls) flavor of LC! :)
No controls on back of center console, a/c and heat controls in 3rd row ceiling.
Very cool.
Does the high low heat switch engage the rear heat no matter where the rear slide temp is set?
That would be good and then you could leave the rear ac set to cold.
What is date of manufacturer?
Could have been when they were switching from 99 to 00 production.
Very cool.
I have the same controls on the roof of my drivers side 2nd row for what its worth - 2000 TLC
The high / low buttons control the fan speed, the air temp is determined by the slider
Hot air only blows from below the center stack (not through the vents in the 3rd row roof)
If you have a weather tech digital fit rear mat be sure to trim around the center stack otherwise it will block the vent
What's a good PSI for these 33" tires im getting put on? my rig is pretty much empty with no added weight except me and my gf. Mainly highways
35 PSI if they're E rated. Matter of opinion though, I run 35 when unloaded because it keeps some of the comfort there.
Sweet, then i'll tell the tech to fill them to around 33 psi or something. I hope they don't feel too heavy and slow me down.
More than you ever wanted to know about tire pressure.
He has a high low heat button on his dash beside the rear AC button. Very strange to have both on a 2000 model when rear AC became standard.
Ahhhh- totally missed that. Thanks for the clarification- yeah that is weird.
@JakeTheSnakeNH Would be easy to just try the HI/LO heater button. If it doesn't work, then the button was added. Some folks have added the button for other uses. It is pre-wired and the output is under one of the front seats.
Very possible. Maybe it is prewired for laser beams or extra lights or something insanely cool.
