Now for new cabin air filters. Ahhh fresh air.
I googled the fridge slide, ouch on that cost!
Gorgeous rig! What size tires?Wanted the Mako to stand out from the crowd. The goal was to mimic TRD styling, and make it look like this could come from Lexus. I used Rustoleum Flexi-Dip for the base, and gloss red for the top coat. That way it's completely removable. I think I'm going to pull the trigger on some Tundra TRD wheels, add TRD hub caps, and get some General Grabber X3's to continue the red theme. I know, the tire... I ran out of plastic
What is the suspension / tire setup on your rig? It's beautiful!
View attachment 1446435 Swapped out the factory HU with a Pioneer 8000NEX. Also deleted the cig lighter and installed dual USB wired back to the Pioneer for Apple CarPlay capability.
Next up is sourcing a label/cap for the transfer case shift knob...
Hmm, didn't know it was an option. This is my first LC, though, so no frame of reference for me. It's a 2000, and I'm in NH. Original owner was in California.Where are you from/where is the truck? Just wondering because of the rear a/c and heat controls. I only have one button which is on or off. The temp and speed can only be controlled by the panel on the ceiling in the back (driver rear area). I mainly just leave is set on 70 degrees and in "auto."
I was wondering the same thing!!Where are you from/where is the truck? Just wondering because of the rear a/c and heat controls. I only have one button which is on or off. The temp and speed can only be controlled by the panel on the ceiling in the back (driver rear area). I mainly just leave is set on 70 degrees and in "auto."
what are you replacing it with?Finished the first transmission flush ever on the truck. 138k miles. I was hesitant to change it, but after seeing the old fluid, I'm so glad I did. I actually had a heart sinking moment when I pulled the drain plug because the fluid was so black I thought maybe I accidentally pulled the oil pan plug.
Some more info here:Where are you from/where is the truck? Just wondering because of the rear a/c and heat controls. I only have one button which is on or off. The temp and speed can only be controlled by the panel on the ceiling in the back (driver rear area). I mainly just leave is set on 70 degrees and in "auto."
