Over the last couple weeks I have been executing my winter maintenance and started my winter build plans.. maintenance items completed:
Parts being installed now:
- new TPS
- replaced inner and outer front bearings, regreased
- greased prop shafts, rear Upper and lower Control arms, panhard rod
- rebuild starter
- cleaned alternator
- replaced fuel tank primary fuel filter
- removed all carpets, cleaned and dried
- wire loomed all exposed wiring under carpets (running to aux fuse panel and dual amps/sub)
- greased BIOR rear bumper spindles, pull pins with copper based anti seize
- removed skid plates and cleaned mud/debris from undercarriage
- removed rear speed sensor, DS side - was throwing a code.. cleaned it, put it back in, still throwing code.. new sensor on order
- cleaned throttle body
- cleaned all fuse boxes under the hood from swamp sludge (100 went swimming last month)
- cleaned all electrical connections, sealed with dielectric
- replaced two seized pullies - tensioner idler and one ordinary idler (it seized and blew my serpentine apart)
- new serpentine belt
- removed rear cargo system for repainting/rubberizing
- front and ear TJM pro lockers
- master install kits
- Slee UCA's
- fix pesky rear right speed sensor
- rebuild rear end
- clean seatbelts
- repaint and touch up sliders/skids/bumpers
- install front and rear lockers
- install slee UCA's
- alignment
