Jim S.
I have the the FZJ80 pump in my 2FE 40 tank. Been in use about 11 years now problem free.In tank set up is where its at! Good choice! Use an fzj80 or 2uz fuel pump. Very quiet compared to walbro
Oh you went and done it now!!Looking forward to that simple install.
Something I Ran into this week.. my slave cylinder rod is about 1” too long. I’m wondering if I used the wrong pivot fork or the wrong throw out bearing..
@cruisermatt any input?
Thanks @cruisermatt and crew
Well I see your problem clear as day.
That’s the 3-speed fork and bearing hub.
Sorry![]()
I was afraid of that.
Guess I’m on the search for the 4 speed one.
Any chance you have one you want to part with?
No need to search. That’s the easy part. I’ve got plenty of them here
Those “small” days really make a lot of progress to bring the end result.Small day again yesterday.
-Exhaust welded out
-Oil pressure sensor adapter installed
-Fuel tank prepped for ring- first cut made and didn’t go boom
- Clutch Parts arrived from Florida from Matt
Flex pipe or flex joint. I’ve started using them the last few years and they are really nice.@clrussell is there a technical name for the steel woven fitting between the flange and the cat?
That’s the important part of itTank cut, welded out, and some paint.
Managed not to die
