What do I have? 40 newb
Fuel pump in, power and ground ran, return fuel line made.
Need to drill a hole in the floor so I can route the pressure line and filter setup.
Slow roll week again. Little things done though.
Wiring hooked into factory harness, we have ignition and crank signal. Fuel pump gets power. OBD2 port installed. Fuel lines finished. Oil poured in engine.
I think I could pour gas in it and start it.
Still need to swap clutch fork, finish fan shroud, and all the other things.
Something about 95* outside makes me want to float around with the family.
You ever mix these up?
Dropped the trans last night (literally, it fell off the jack) at 10:42.. managed not to wake the house or get squished.
Swapped the clutch fork and need to find time to poke everything back together.
I’m going to sacrifice some sleep this week as I need to make bounds to get it drivable.
Kids start school in 2.5 weeks and I’m going to do my best to drive them to school on the first day again this year.
Kids start school in 2.5 weeks and I’m going to do my best to drive them to school in it again this year.
At first when I started reading the double post I thought you dropped it again.
God speed my man
Finally feels like I made some progress over the last few days.
Proper Clutch fork / throw out bearing installed
Park brake reinstalled
Transmission mount reinstalled
New output seal and speedi sleeve
Filled up power steering fluid
Had a beer.
Looks like the solution here is to cut the slave cyl rod down to proper length? Far from a good picture.
Fan shroud finished
Radiator hoses mocked up
Power steering cooler mounted
Battery cables ready
Front driveshaft ready (forgot to take the rear to the driveline shop this week)
Needs o2 bungs, fuel pump wire corrected and some fuel which I’m headed to pick up soon.
Still a long ways to go.. but it has the chance of running this weekend.
Accomplished a lot today. Time with family.
Quite a few odds and ends. 02 bungs, fuel pump wiring, fuel.
Get it all hooked up and pushed outside. Call my 3 year old over to help. I give her a crash course in starting it while the battery is unhooked. Ask her to practice while I’m pouring fuel in. She’s ecstatic.
Hook up battery, fuel pump primes quickly.
Ok start it.. crank crank crank. Hmm. Do it again.. same.
Well 💩
She needs to potty so she runs up stairs and I grab my super duper basic code reader. No engine RPM cranking. After a Quick Look I diagnose the fact I never plugged the crank sensor in. Plug it in, and wait for her to get back.
Ok I tell her let’s try again.
She hits the key and this is the screen grab some the video.
Safe to say it runs and that’s a huge step forward. Went to dinner came back home and hit the key. Boom started like a brand new one. Man I love the LS world.
So many little ends to tie up. So many big pieces of the puzzle left. But I can see the light.
That is just tip of the iceberg with these motors. Smooth easy starts are nice, but it’s the throttle response that gets me excited. The F was a good motor. The SBC was sweet. The LS is a joy to drive.
A joy I am beyond ready for. I haven’t drove my 40 since April. I might not even take the top off this year 🙃
Soon..
So I am guessing it turns out if you use a 60 series top plate you need a 60 series back up light switch?
And more importantly a 60 series shifter?
I’m guessing with my timing @RevISK has already sold his
