What is this part and what does it do???
TemboTusk
Supporting Vendor
GOLD Star
Anaheim, CA
Website
www.tembotusk.com
1967 FJ-40 Photo is of a silver cylinder just above the clutch pedal. What does this item do?
Thanks!
I'm going to guess "flasher relay".
I would second that. Turn the ignition on and activate your turn signal. Put your hand on the item in question. You should be able to feel it clicking in time with the blinker.
Never mind. Didn't see second post.
My blinkers work with a separate relay. By Hazard don't so no clicking.
Swap the flasher from the turn signals over and see what happens.😉
And you really should scrape all that blistered paint off your floorboards ☹️
Just to be clear. The image I have of the cylinder above the clutch pedal is the Hazard relay? I will swap them to see what happens.,
The blistered paint removal is on the to-do list. Brake master cylinder work resulted in a bit of fluid spill. OK, more than a bit!
Thanks
Thanks
By process of elimination, if your turn signals flash, and that unit does not, it is not the turn signal flasher. The only other cylinder of that type on a ‘67 is the hazard flasher. So that would be the hazard flasher.😊
IIRC the turn signal flasher is next to the inspection lamp plug on the passenger side of the front heater.
Thanks for the comfirmation. I have just pulled the hazard relay . The part numbers are still visiable. I will try to cross referance it for a replacement.
I have an aftermarket signal flasher next to the original on the passenger side.
Thanks!
The round ones are obsolete Jerry. I think they both superceded to the 12H04, with the first five digits remaining the same.
I am underimpressed with the 12H04 and have considered trying a simple aftermarket one. But I haven’t because I’m a little lazy, and with 4 Landcruisers, there always seem to be higher priorities elsewhere.
I'm sure a heavy duty flasher relay should work. I will try it Thanks Mark!
Agreed on the 12H04. A steel case Echlin 2 prong flasher (I think Napa sells them Stateside) fits either in the OEM clamp or you can gut the round OEM housing and hide it in there. Modern flashers hidden inside OEM cases fix all flasher ground/resistance gremlins immediately without further fault tracing.
When I bought my 68 the wiring for the lighting was a mess. I managed to get everything working except the hazard lights. A few years later I was working on cleaning the cowl vent and found a fuse in the wiring harness right under the vent. Replaced the fuse and hazard light have worked ever since. Now if 71 still had the fuse is fuzzy. I stripped the wiring harnesses out of a 71 which I think still has the fuse. Still have that harness in box somewhere. Fuzzy in mind because pulled the harness back in the late 1980s as a possible replacement for my 68 if ever needed.
That is a very good point…and a very obscure one John. Thanks for bringing that up.😊 From time to time I forget about that fuse.
Every once in a while your anecdotes have some real gems in them.😊 And when people research the key words hazard flasher not working, that should come up. Total PITA to get to. But still, abundantly better than not knowing it’s there.
