What Did You Do with Your 80 This Weekend? (41 Viewers)
I winched out a 4 door, full size duramax Chevy thingy hung up on frame and axles..lol
I'm curious if you noticed an old to new seat weight difference? I've contacted the manufacturer and am now in the process of convincing myself to pull the trigger.
Zona
I found the new seat with bracket is about 4lbs less!
My new delta panhard bracket is in, and I will need to adjust the adjustable panhard bar so it is the factory length.
Would anyone happen to have the length of the rear OEM panhard bar? (eye to eye) My search skills are not returning anything
Can't it be adjusted in place?
Just install the bracket and then adjust the track bar until your axle is centered at ride height.
It can, I would like to know the OEM length so I can use that as a starting point
With weight on the truck and the bracket in place just take your adjustable one and make it the length needed.
A panhard should be level and the bolts should install with no issues.
Creative Custom Finishing in Corona does it again.
Sent out customer’s LX450 valve cover to be professionally painted as part of a much larger build.
Turn around was much quicker than expected and the only thing that slowed the process was deciding on the colors.
All Toyota paint codes using PPG paint:
- 1507 Helios red
- 565 silver
- 4898 grey
Damn that looks nice!!!
Well as the pnw continues nto get smashed with weather, it's going to **** me on getting my truck back.
