What Did You Do with Your 80 This Weekend? (110 Viewers)
These showed up at the door, Thank you Joey!
Supposedly yes, they only have up to 5 inch bracket but should be close enough. At 6 inch tea gel if panhard is quite extreme so it should help a lot.
Anyone has experience with 5-6 inch lift with bracket?
Yea my buddy has the 5 inch on his helped a ton, night and day difference, no interference with anything , he is running slee 6 inch lift
She was thirsty... might be a new record!
Then pulled out of the gas station and saw her twin. Never seen this one before in town. I waved excitedly but the lady was too busy yapping on her phone.
She wasn’t exactly running at this point... I ran out in front of the gas station. Started her up and ran out pulling up to the pump. Eek.
Since fixing the main crank seal and the oil pump cover o-ring last weekend and being drip free for a few days I treated the rig to some Rotella T6.
Also, drained and refilled 4 quarts of transmission fluid.
Oil level sensor o-ring and speedometer o-ring also replaced.
Old and new crank shaft seals. I think the old is upside down but it was so far gone it was hard to tell side by side.
View media item 76527
Fun drilling out the 7th screw.
View media item 76525
Source of the flood. Flattened, brittle, and broken o-ring. Put this off for a few too many years.
View media item 76526
Remounted the wifi MPPT controller (blue box) to give quick access to the new Jetboil Minimo. Two shelves above is where the gas is stored, the kitchen/utensils are in the silver case, wood cutting board above, water spigot is next to the spare, and the Mountain house/breakfast items/coffee bar is in the tailgate. This makes everything needed for cooking accessible from one standing position and fit on the tailgate. My original Jetboil (above the new) is one of the first design still working great that uses a Primus valve:eek: just wanted/needed something that simmers to expand my menu.
FVv-1T3iYSPvRWbh05mh_6TQdMI9A7g1Wx4G9ANjMySEaqbSa8n5Xx4iMN3oCvylElzGGNKiaMMe94k-8l26FMMqsjJHTTIPEYtRlG2BT42OMx7UiVYqtG8dyqtma0oOFyKFrEJqb_LcEHkRZWRXF38mt7NOTUjQcIIMI9hYk6h-0Iro4ER8jgorC1-9rVttjy11hXcrie_bUdSKySWbHTlPLdGcnypkdnq9v1RlvMmFetQoX_Jf9fmdqiNybPhDHhanfyzdcTCvbiTXHR29MmhQ5EwIr9QdkujAtbTbX6u9TYTsOzaMfMpkR8Dri_OEHhDxFj8l665dX6BVBmyLX6t58ZUR6XybGnoD-pUbzw7T44w11S8e9FZC9G63sHMubg0mYm54cTB597i0KwgDKnE8OWJLoDTwF729xvX1pPFU5lvsM0hkrDEiW_4Zk0g5fGW-AGKx80GnXJQ-BcJFCMPZPJulpm9UmIlaCSlXOM8PSqbXuxhn69DXVNl7t5ia0zZoBiwzdzLLvzXrhG6RKuTbVANjHCTRJozDOF2zsmIERbDf32Ova515BRpO6QG23NZjrxqAX8fDL_IiordmZZDAx01zQ7yy2h71usTq_mlowxHCfuGf-Yce5BzMQvM6=w704-h938-no
Got this bad boy, after my 3rd used one gave up.
Ran to Sedona for the day with the family, truck did great until I tried to play some music on the way home. Found both 30A fuses in my amp blown. I warily replaced them and and was met with a small pop, sizzle and sound of something popping inside followed by a trail of smoke from the amp. My poor 13 year old Apline amp has moved on to a better place. :cry:
Time to replace her, that's not going to be cheap. :flush:
How do these keep breaking?
25 year old plastic, it gets brittle with age. I spent quite a bit of time working with an injection molding company about potentially making new ones, they said the material used on these doesn't age well and sunlight/heat break it down. Unfortunately to cast and make new ones was cost prohibitive, so I had to buy OEM parts.
$2.68 for gas? ? Dem,, California what's going on? Can't remember last when gas was that low. You need to have atleast 3 cruisers
