Been a busy weekend so far... And I still have tomorrow off
- New shoes - Toyo Open Country AT2 285/75 R16's (local tire shop matched Amazon price so that saved me $50/tire)
- Tightened front wheel bearings to 25ft/lb inner nut, 47 ft/lb outer nut
- Topped off knuckles with moly grease
- Replaced all bushings in front control arms and panhard with OEM
- Cleaned front axle breather fitting
- Replaced rear end caps on running boards
- Added rechargeable motion sensing LED light bar to flip up window
New shoes
Replaced control arm bushings. HF 20 ton press wasn't cutting it (safely) and so I pushed out the rubber with the press, used a sawzall to notch a section of the bushing sleeve, and then chiseled out the notch section. The old bushings practically fall out at that point.
Running board end cap part numbers (because so many of us are trying to save our running boards
Rechargeable light bar for LCP window. It came with internal mounting magnets that weren't worth crap, but I epoxied several neodymium magnets to the back and it holds tight to the adhesive metallic strip that came with the light.
The motion sensor works great! Open the side window or the rear hatch and the light comes on and stays lit as long as you are present. Close the window/hatch and 20 seconds later the light goes off. Motion sensor does not activate through glass, so walking around the vehicle won't set it off.
This is the light I used:
https://www.amazon.com/Rechargeable-Cabinet-Wireless-Lighting-battery/dp/B07FNNHHST/?tag=ihco-20
