What Did You Do with Your 80 This Weekend? (50 Viewers)
Are you going to paint your rear bumper this time around?
Yes, blasting and painting the 4X4Labs rear bumper is on my list. I may sell it and go will a custom tube set up that incorporates rear quarter protection up to the passenger doors. Either way, there will be side protection added.
My Rear red/white hatch lighting works too good so I needed to mod my mod.:rolleyes:
Night time pictures
I found a small touch dimmer (plus a lot of other functions I dont need) that remembered its setting when the power is off. This was important because I did not want to need to turn on the dimmer every time I open the hatch to get light. In the end I now have a selectable red/white light, dimming capabilities, with memory.
Night time pictures
View attachment 1205042 View attachment 1205044
View attachment 1205045 View attachment 1205046
Link?
That looks so peaceful. Your little friend Is watching your every move. My little dog Is so afraid I may leave without her. Nice Job..! :)
Replaced the Toyota sombrero with the teq sign
Real sly there Phil pulling out that reverse psychology. That's it, I'm moving to Arizona.
As for gas prices... the taxes out here are over a $1.00 per gallon.
But high taxes are only necessary so the government can decide how to take care of us with our own money. Feel the Bern!
In Big Bear, not in my 80, but was fun none the less. Little 2dr spider crawled over some rocks with ease. 20160207_114032.webp 20160207_114017.webp 20160207_115156.webp
You know I was just having fun with you...
As for tube rear bumper, I really like what @Apounder did with his rear bumper. Also Trail Gear is coming out with tube bumpers very soon. I came across my bumpers for a good price, but I like the tube bumper look on my rigs the best. @Nay & @bugsnbikes has a good looking tube bumper also.
Almost done. We have to finish the jack mount and the fold down table behind the tire. After the final touches are done we will spray it with bedliner.
Looks like you did a thorough job. What sort of bender did you use? I'm tempted to by one but good ones are spendy and then there is the tubing that will be trashed during the learning process so I'm undecided on this tool purchase. Any input?
It's my buddy's bender. It used to be manual but now he has a hydraulic air activated piston. It's a simple set up on a stand and easy to use. I think he bought it used some years ago so no real input on your tool purchase. Sorry.
Posed with my favorite rear emblem......
....before heading out to the futbol game, that's soccer to my north American Mud friends out there. I was literally a soccer mom in a Land Cruiser today....too cliche?
We lost....0 to 3.
@AlohaJen I was there this summer with my daughter to play in a soccer tournament. That's a nice soccer facility with tons of soccer fields and open space...like nothing we have in Los Angeles!
Saturday buttoned up the final Diesel Conversion wiring behind the dash and a few more items in the engine compartment. Tested with the battery hooked up, even though there is no motor or trans in the bay. :cool:
  • Sedimenter circuit and light, check
  • Turbo light and coolingmist adjustable switch, check
  • Tachometer wire ready for IP
  • Glow switch wired for glow relay, check
  • NSS converted to a clutch safety switch/relay, check
  • Starter circuit sorted out and tested, check
  • Modified Landtank Carbon Canister Bracket to hold glow and starter relays, check
  • Added a new ACC triggered BlueSea fuse panel in the engine bay with custom bracket built, check
  • Figured out which wires to use to power the IP fuel cut-off and fuel heater, check (from the igniter circuit)
  • Mounted OEM fuel filter bracket, check
  • Mounted OEM vacuum pump and hard lines, check
  • Removed old fuel lines in preparation for custom 12mm feed line, check
  • Bent old fuel return line to work with IP, check
Tomorrow drill a bunch of holes and mount up the Safari Intercooler.
Photos would be great. You are doing a number of projects I have an interest in doing! Thanks!
