What Did You Do with Your 80 This Weekend? (17 Viewers)
That first pic, with that big rockthingy - GREAT!
At least your oil pressure and engine temp look good.
Ditto. But I wonder if the oil pressure mark is diff between the 3FE and 1FZ-FE? Mine is always right above 1/3. Has been for as long as I can remember.
Oh and I have a 3FE. :)
Pulled the roof rack off, won't need it till march or so.
Fiddled with the washer diverter thingie, broke it.
:doh:
Ordered a new one. In the meantime I teed it off with a garden dripper fitting I had laying around.
:hillbilly:
How to get absolutely nothing done in 61 easy steps.
Or.
How my Saturday went.
  1. Buy ARB lockers and have them installed. (Ok this is not a bad thing, pretty cool actually)
  2. Buy 2 gallons of 80W-90 gear oil in anticipation of the oil change after the break in period.
  3. Lose the receipt
  4. Drive a total of 1,500 miles
  5. 10:00 AM: Park the LC in the garage and prepare for the oil change
  6. I do not drink, so step 6 was skipped
  7. Realize your waste oil container is full and needs be emptied before the diffs can be drained
  8. Swear
  9. Pack up the container in the other car
  10. Remember that your kerosene container is empty and it might be nice to have some heat
  11. Pick up the container and see that the cap/nozzle is broken and would spill everywhere if used
  12. Swear and make a mental note to go to Tractor Supply Co and get a new nozzle
  13. Take the used oil to the collection center
  14. Get chewed out by the operator for not stopping at the empty operator shack so I could wait for him to tell me how to get to where I already knew where to go
  15. Dump the oil and head to Tractor Supply Co for the new nozzle
  16. Find they do not have one your picky ass likes
  17. Go to two more stores and finally buy one at the hardware store
  18. Head home
  19. Find the oil you bought just for this occasion
  20. Think to yourself “I better check the ARB Manual to see if they have any special requirements”
  21. See that ARB recommends a synthetic blend
  22. Swear because that is not what you bought
  23. Put the two gallons of oil in the car
  24. Put the kerosene container in the car thinking “At least I can get the kerosene now”
  25. Head to the kerosene supplier first because they close early on Saturday
  26. Arrive at the kerosene supplier and see the gates are closed. See that they changed their hours.
  27. Swear
  28. Take your son to Taco Bell for lunch because he is hungry and you have been running around all morning
  29. Head to the autoparts store
  30. Try to return the gear oil without a receipt
  31. Be happy they will exchange it for the synthetic
  32. Find they do not have the correct weight as recommended by ARB
  33. Ask if they will refund your money without a receipt
  34. Answer the question “What is this going in” from the clerk by saying “A 97 Land Cruiser”
  35. Answer the question “What is that? A Toyota or something” with “Yes a Toyota”
  36. Have the clerk argue with you that the original oil purchased is the correct oil according to his computer
  37. Argue that the vehicle is no longer stock as the differentials have been changed out for aftermarket lockers
  38. Have the clerk argue that his computer says a 97 landcruiser with lockers still takes the same oil
  39. Argue with the clerk again that they are no longer stock differentials
  40. Have the clerk tell you he hates when people mess with their differentials. ?????
  41. Finally the clerk hands you less money than you paid because he does not know if you bought it on sale.
  42. Swear and be happy you are leaving with something
  43. Go to several other stores looking for the recommended oil
  44. Do not find it
  45. Decide to call ARB to see what else they recommend
  46. “You have reached ARB during our non-business hours……………”
  47. Swear
  48. Give up on the oils change for today and decide to replace the antenna mast. That will be an easy 5 minute job and make you feel better
  49. Remove the nut on the top of the antenna and have your son hit the “up” button
  50. Get the antenna all the way to the top and find that it will not come out all the way
  51. Have your son work the antenna button up and down several times hoping it will work the cable loose
  52. Swear and think “No big deal I will just take the whole unit out, disassemble it and remove the old antenna
  53. Remove the other bolt holding it in place and try to work the antenna out of the hole
  54. Realize the antenna cable is too short to allow the unit to angle properly to come out.
  55. Try to reassemble the unit back in place
  56. Drop the bolt and have it disappear
  57. Crawl around under the truck for 15 minutes only to find it inside the the slider
  58. Try to reassemble the unit back in place, Success!!!!!!!
  59. Clean, lube and straighten the antenna as best you can and call it good.
  60. 6:00 PM Call it a day and thank your son for hanging out with you.
  61. Post a ridiculously long list on IH8MUD
Or.
  3. Lose the receipt
  8. Swear
  18. Head home
  27. Swear
  44. Do not find it
  47. Swear
have you started drinking yet?
Some friends and myself went out to the Palo Duro Canyon, and we set up camp very late as we got stuck in a lot of traffic on I40. Then we woke up several hours later to go ride as many miles as possible on Yeti's new lineup.
Rode the SB6c to start with. It's a lot of bike and we weren't familiar with the canyon, so I never fully got to open it up. Then went with the SB5C and it might be the best bike I've ever ridden. Their 29er was also amazing.
The Yeti cooler on the swing out is a life changer.
Couple updates:
-rolled 160k
-sitting at Sears waiting for them to test for a parasitic draw on my battery so they'll finally warranty it (3 weeks)
Since pics are like p*rn around here, I have a couple :hillbilly::flipoff2:
And yes, the 80 gets the garage. The little tugboat TDI Jetta gets the hard life and is subject to the elements.
View attachment 1196293 View attachment 1196294 View attachment 1196295
I've never seen my oil pressure that low. Even hot at idle. May be fine, I don't know, but sure looks low.
The gauges senders are mechanical and wear out. Mine read low with the pressure well well above minimum per manual, replaced sender and it reads normally.
Pretty common issue.
Or.
  3. Lose the receipt
  8. Swear
  18. Head home
  27. Swear
  44. Do not find it
  47. Swear
If I were you, right around step 11 I would substitute all the remaining steps with number 6. At least you got something out of your day. Quality time with your son.
The Yeti's have come a long way and now they are one of the best line up when comes to carbon MTB. In fact the SB95c is the only bike that have tempted me to get a new bike since 2012.
I rode up to N. Georgia to play in the snow with some old, and new, friends. Started off with four other vehicles (you know, that original crude design that Dr. Toyota took and perfected), and before we’d driven 30 miles we had to stop and get gas for one, coolant for another, and oil for the third.
Then, while we were stopped, we saw a mutual friend across the street at the auto parts store repairing his vehicle in the parking lot. So, we all drove over there to watch, and then he and his buddy in a sixth Jeep joined our convoy. When we finally got into the snow, we met another 80 who was waiting on us, and picked up an additional two or three Jeeps along the way.
By the end of the day we were back down to the original five vehicles, and the forth Jeep had busted his front sway-bar requiring a quick trail repair.
12508815_10153880492321115_5873135953471238153_n1.webp 12508868_10153880444411115_3106118883710231988_n1.webp 12540733_10153880492501115_7374423999852616741_n1.webp 12548852_10153880492361115_6001166393486819346_n1.webp 12565389_10153880492456115_4913182760782492644_n2.webp
Figured that but seeing as he has 30K less miles than me, and mine works approriatly, he might of had a problem. Any pressure is better than no pressure!
Got my Webasto running again. Even though my 80 doesn`t move when there is salt on the road. Was planning on removing my injectors and get them rebuilt, cant be arsed to get off the couch. :deadhorse:
What did it make in 2wd, I was always curious if locking the center diff might free up a little hp.
Makin the mad power. ;) Shenanigans on a Saturday.
Friends trailer dyno. Pulled the front driveshaft off. It created a certain amount of HP and torque :)
PJ
  • Back
