I thought about contacting BFG cause like I mentioned above, tires have less than 1500 miles, but wasn't sure if the use of the skinny oem steelies would void any type of warranty...
yes, 33X10.5X15Are they 10.5’s? If so I would bet they’ll call BS on the failure.
I had a 30k set of k02 warrantied due to safety concerns. All four tires had cracking between the lugs and looked like 10 year old tires. My spare that had never been on the ground looked like new, and it had been on the bumper exposed to the sun for years.I’ve heard of that happening with the original KOs but they changed the rubber composition for the 2s. That’s terrifying. Glad you’re good.
4wp gave me half my value back of the tires at 5/32 left. Give BFG a call directly.
My big weekend job is done!! After putting up with a broken bonnet stay clip for 5 years (and using various hardware shop solutions that all broke), I asked at Toyota - and they still have them in stock!! $3 and it is fixed with a genuine part!! So happy!!
Yes, yes, yes, yes, yes, yes AND yes!!So, new oil pan gasket, RM seal, new clutch, resurfaced FW, new OEM hardware, new TC, with a new H55F? I'm jelly.
Sorry - I didn’t even bother with a receipt!Mind sharing the PN?
I think city racer has them. I fixed mine when I replaced the swivel grommet just a couple weeks before adding lift shocks.Mind sharing the PN?
@ToyotaMatt has them too, along with the rubber grommet that goes on the other end of the rod.I think city racer has them. I fixed mine when I replaced the swivel grommet just a couple weeks before adding lift shocks.
@Gretsch, where did you get that fuse block? Did it come with the relay bracket? It has a "+" bus?Installed my new Koito Light Kit:
View attachment 2634412View attachment 2634413View attachment 2634415
Needed to rearrange my aux fuse box a bit to get everything to fit. Made a little relay rack for the Koito relays along with my Hella Black Magic light relays. Now they all fit together and are out of the way of hood springs and whatnot. Install couldn't have been easier with how the kit is packaged up. Hopefully this kit will get me improved light from the stock setup. I still can't believe this thing is only $50.
Part number for the hood release cable?Replaced the hood release and replaced my mismatched lug nuts with the correct ones.
