LAMBCRUSHER
dropped exhaust pipe, pulled steering shaft and box. removed egr cooler and pipe and replaced egr gasket at #6 manifold port. Reassembled......
bought it, brought it home on a trailer, stood and looked at it for a good 15 minutes with a huge grin....
I just bought the pieces for the tailgate glass run and they made my window worse. They are to darn rubbery, they grab the glass and made me ruin the motor before I yanked them out. Went back to my old crusty ones and threw my spare motor in and it works ok again... Just giving you a heads up on those pieces, I can't speak for anything else as I haven't used it.
Just brought home an 87 2f to put into my 72 pig. Just got to find a way to get it off the trailer![]()
. its how I unloaded my 55 ...took out the aluminum radiator with a hole in it and put in the 73 Fj55 radiator I had on a shelf.
The Taurus fan fits perfectly as a pusher. A tiny bit of trimming and it's a tight fit on all four sides. I had to pull the latch plate and the support rod, but they don't do anything anyway. I shouldn't have any problems with it getting into the water pump pulley if it works as a pusher.
I have heard of this problem before and people that had this problem mentioned that some spray silicone should be used...It will messy up your window for a bit of time, but apparently it helps with the problem you are referring to. I think they had to do this about twice a year.
I have heard Syl Glide is good for windows
Todd,
Just some random questions. Are you running just the pusher or a pusher and a puller? Did you keep the a/c condenser, and PS cooler in front of the radiator?
i just bought the pieces for the tailgate glass run and they made my window worse. They are to darn rubbery, they grab the glass and made me ruin the motor before i yanked them out. Went back to my old crusty ones and threw my spare motor in and it works ok again... Just giving you a heads up on those pieces, i can't speak for anything else as i haven't used it.
is this the ones on the inner tailgate or upper glass?
Got the rear sill welded in. Will have to wait and paint it tomorrow. It's not perfect by any means but it will do for now.
Would love to see more pics of this. My back two mounts are for ****! I was thinking that this would be a great way to go. Are you going to have a tailgate?
