Axle building day!
You know it! Thanks to you and SNLC for your previous research/posts on the matter. Mostly RHD 79 series stuff. Made more sense than a 'rebuild' to me. But then I nickel/dimed myself with all new everything else in the area and now I'm in deep-deep.Pimp. Did you get the later gear box with the upgraded sector shaft?
For sure. Boiled off coolant can be hard to find.
I don't like that your gauge surged. Toyota is pretty conservative with temp gauges...temperature variation has to be pretty severe to spike an OEM gauge from what I've seen.
And yeah. 1kz heads aren't made by Humpty Dumpty (maker of the LJ head) but maybe his second cousin
yup roads are ready, trails are readyWell , I washed and cleaned 4 months of dust off the 70.All clean and shiny , so I drove it in to my favourite coffee shop and had a hot tea. The snow is all gone and our local highways contractor has washed all the shytty snow removal poisons off the roads, so they are safe for the BJ to be on them again.
Lower rad hose was cold after running and upper hot. Temps stayed normal though, however there was bubbling coming from the over flow and smoke. After cooled, took off rad cap and rad low again. No signs of leaks. Oil is still normal looking. I bought a chemical kit to test the rad fluid to see if there is leak by. Engines rungs great and I don’t know where the fluid is going or why it is not taking from the overflow and check line, it’s clear to allow flow. Got an OEM 82c stat from Japan. Sucks bc this is my primary vehicle and I’m moving in a couple months to Florida with orders so I got to figure something out. Will post results from rad test to see if head or gasket is bad.Fingers crossed for you its just a t-stat stuck closed.
Since we are on the topic of thermostats...I remember someone posted the ''aussie'' thermostat for the 1kste. It was a toyota part number that they all run down there to keep things running cooler. I dont have the part number but I remember it being the ''71c'' Toyota Thermostat.
thats pretty much what happens when the headgasket is bad, it pushes the fluid to the overflow from pressure of combustion over pressuring the coolant system, where it overflows, and then you're low on coolant, happens enough youll be low enough on coolant and overheat.....Lower rad hose was cold after running and upper hot. Temps stayed normal though, however there was bubbling coming from the over flow and smoke. After cooled, took off rad cap and rad low again. No signs of leaks. Oil is still normal looking. I bought a chemical kit to test the rad fluid to see if there is leak by. Engines rungs great and I don’t know where the fluid is going or why it is not taking from the overflow and check line, it’s clear to allow flow. Got an OEM 82c stat from Japan. Sucks bc this is my primary vehicle and I’m moving in a couple months to Florida with orders so I got to figure something out. Will post results from rad test to see if head or gasket is bad.
Yeah I kind of figured that much. I have some work cut out for me because I haven't replaced a head in over 30 years. I need to find all the gaskets and correct setup, but should probably tear it all down first before I start ordering things. Part of me wants to now just pull the engine and trans and put in something I can get stuff at the local parts store that would allow me to drive across country without worry, but have not researched the best conversation engine and trans for my 78 Series.thats pretty much what happens when the headgasket is bad, it pushes the fluid to the overflow from pressure of combustion over pressuring the coolant system, where it overflows, and then you're low on coolant, happens enough youll be low enough on coolant and overheat.....
Finally troopy is moving by its own power. Picked up from @orangefj45. The crew there is fantastic. Towed it to my shop (we actually build very high end joysticks for the military drones) and spent the day today modifying the prototype grill that @kelly saad so it will fit with the intercooler. I’ll change the front screen to the small hexagons like my 80. I still need to adjust the hood and then take it all apart and install the new fenders that are being painted. Bumpers curtesy of Luke 4x4labs.
View attachment 3867423View attachment 3867421View attachment 3867422
