What did you do on your 70 series today? (19 Viewers)
Spring is in the air , time to scrub that 70 inside out
Looks Ike it has some nice, big drain holes in the lower panels to help with drying it out
I cut that one in there so the risk of contracting the hanta virus is lower when I start on the repair 🤣
This is the “jadebean” troopy , frame rails where packed with red mud so that was the first thing to get rid off , interior panels where stuffed with it to and all drain holes plugged up .
It's in good hands!
that better be a toyota forklift 😁
It is , used to have a 6 ton toyota diesel forklift but got tired of getting that heavy thing stuck in the gravel so I bought this 2 ton on propane , best purchase ever
Had the muffler man fix my exhaust on frame rail rattle and add a free flow muffler today. iPhone decibel app recorded 88 max on the way there... 70 max on the way home. Should set off fewer car alarms and have less pissed off neighbors now.
Talked a local Ace Hardware into cutting me a new key with my supplied blank, never really cared for the GM key it came with :rolleyes:
Side exit? Ooooh that looks good! Did you get any more shots? Would love to see from offside... What diameter did you go with?
At last I found 24 volt instrument cluster with tachometer and differential lock indicator. The shell had a few damages, broken fasteners etc. so it needed some fixing.
picture.php
The original has too few gauges..
picture.php
So I disassembled a broken LJ70 instrument cluster and used bits from that, with small changes the LJ70 shell works well.
picture.php
picture.php
..and reassembly with new glass. The 12H-T bellhousing has a HJ61 tach sender, believe it will work with tachometer. BJ75 has wiring for the tachometer ready in the harness.
I hope everything works when I get to test it...
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
What was the work required for getting those gauges to work?
I don't know for sure because I haven't installed it yet, but it should be quite easy.. Two wire harness connectors behind the instrument cluster are the same in both, the original and the new instrument cluster, so that should not be a problem. For oil pressure gauge the sender must be changed to different type, currently it is on/off-type switch. I'll know more in a week maybe, when I get to install the cluster to my troopy..
I'd be happy to hear if anyone has experience with this.
With the current USD / AUD exchange rate it was a good time to place an order. These skid plates will come in handy on my weekly trip to Walmart. 😊
** Photo courtesy of Odd Iron Off Road
