I don’t know if that stuff is a new age upgrade, but it looks like an optical replacement for old school points. That bolt adjusts the timing I’ll bet.
The “lifting” process is normally quite easy. (Doesn’t normally require any of that Knights Of The Round Table stuff.)I'm working my way through the quirkiness of my new-to-me FZJ75 GCC pickup. Figured out why it cold started like crap: there was a short vaccum line not even connected on one side. And the idle seemed to have been set super duper low. Seems to be working better now.
Might be a dumb question, but is there some trick to selecting L4? I am lifting like I'm trying to pull excalibur out of a rock and nothing is happening. I can't move the selector beyond H4.
look underneath and take a picture (s). try pulling back and then sliding to the right. I think that is the wrong knob. that's if you have a split case transfercaseI'm working my way through the quirkiness of my new-to-me FZJ75 GCC pickup. Figured out why it cold started like crap: there was a short vaccum line not even connected on one side. And the idle seemed to have been set super duper low. Seems to be working better now.
Hmm doesn't look like a split case transfer. Sorry can't help you. Try looking at the linkages and figure out where the lifting motion would come into play. Have someone up in the cab play with the selector lever, while trying to figure out how it should move.No luck in any direction. The manual says to lift as well.
Are these the pictures you're looking for?
Is that a 1999+ transfer case? I’m a bit fuzzy on 70-series t-case differences throughout the years.
When the price is low enough my ideas really start to flow/become desperate^^ With enough skillz….![]()
Why the new doors?
OEM or the new chinese aftermarket ones ?
I am even later to the party... on my VZ pile of bolts, I had to just pull down as hard as possible to pop it in low. Pushed out easy... I was told to not be shy!Hello,
I am late to the party.
Normally, you just depress the clutch pedal, shift to H4 then pull gently. A click tells you that you are in N. Keep the pull and move the lever, gently. Another click confirms you are in L4.
It is safe to say that the PO seldom, if ever, drove in 4WD. The PO did not clean the drive train either.
If the lever is hard to move, then the links need lubrication. Your photos show dirt on them. Brush it away, apply some WD-40 and let it penetrate for a while. Then try again.
Once the lever shifts properly, apply more lubricant on the links.
Hope this helps.
Juan
