What did you do on your 70 series today? (22 Viewers)
Pulled the rear third member on the BJ73 to address what I thought was a worn out pinion bearing and bad seal. Pinion nut was loose. I'm guessing previous owner hit a rock or something and crushed the crushwasher a bit, but then there was slack. I Snugged it down to a better preload, reset backlash from .015 to .007 and installed a new pinion seal. I had some slack in the driveline and a little vibration at highway speed from the pinion wobble. Hopefully she'll be tight and smooth now.............Spartan locker goes in on reassembly tomorrow.
What I did with my 70 series the other day was drive it to work (like most days), but I did hit a milestone:
Picked a heck of a day for it, too:
Are you able to get periodic specific (appropriate part numbers) wiring stuff for your vintage 70? I would love to do the same to mine
Well, I try to keep it all Toyota or supplier group companies when I can; unfortunately most of the connectors are discontinued from Toyota but available from places like Eastern Beaver, etc., in Sumitumo and Yazaki form.
Installed a spartan locker in the rear end. It functions as expected. Jerky if you're on the throttle turning tight on pavement. It will chrip the inside tire accelerating while turning from a stop. Traction is greatly improved....Install was a bit of a puzzle with the Cclip axles and the "spring plunger holding pins" supplied to aid assembly being too long to rotate/fit in the carrier. Had to snip them off short to get it in and rotate around.
Tightening up the Pinion nut to increase preload/reduce pinion wobble and tightening up the adjusters in the rearend to reduce backlash worked wonders! Driveshaft wobble/vibration is gone. Driveline slack is almost eliminated. Makes it feel like a much newer truck.
Mounted my Auberins EGT gauge into a blank I made for the radio din using leftover black HDPE.
Worked a little more on the bolt on sliders I'm building for my 73. I ran out of gas on a Saturday so I have to wait until Monday to buy more gas to finish welding.
New OEM harness clamps to keep things elegant.
New battery trays and brackets...
Using a glow plug relay from later 24v trucks. A more compact form vs. the original. Mounts the same on the battery tray bracket, terminals the same but the connectors are different. Splice and away we go.
