That is a cool link. Well done sir!
First the OE Electrical tape and now that link to replace the 82122-90K03.
One unsafe aspect of the stock 24v layout is the proximity of the positive terminal to the firewall. An accident or rollover could easily put the positive terminal in contact and cause a fire. At a minimum, I'd install a terminal cover and maybe take some rubber hose, slit it, and install over that protruding seam on the firewall.Finished off the power side of the engine compartment electrical.
Final cable is from a 24v Dyna IIRC. Much nicer than the OEM 1985 unit.
Right on! The rubber cover will definitely help but something similar to this could still happen. This was a failed mount but an accident could produce the same results. I have seen a lot of car fires in my time and a 24v, dual battery system would be much more likely to catch fire. I don't think any current production vehicle would have such a layout.
New OEM harness clamps to keep things elegant.
New battery trays and brackets...
Using a glow plug relay from later 24v trucks. A more compact form vs. the original. Mounts the same on the battery tray bracket, terminals the same but the connectors are different. Splice and away we go.
View attachment 2246121View attachment 2246122
Highly recommend Elliot tape for high heat, grease and abrasion areas...
Expensive but worth it. In combination with the OEM Yazaki tape. Pura vida.
View attachment 2246134View attachment 2246135View attachment 2246136View attachment 2246137
Really bringing the excellence to these improvements @Onur. Looks so well done. You're giving me aspirations for repairs on the Troopy.
Is that Yazaki tape with or without adhesive? I've been using adhesive-less tape on intermediate sections with 3M adhesive tape at the ends to keep things buttoned up. Curious how you're working the Yazaki tape.
First of all I had help from a fellow 'MUD member but here's the link.Nice trunk tray! Where did you find this??
