Today I did research for a future engine swap into the BJ73. My 3B overheated because of a pinhole in the suction line causing a air bubble on the water pump impeller: Hot engine and cold radiator. At a minimum it's blown head gasket, probable cracked head, and possibly bent rods due to cranking with coolant in the cylinders...............I think we're done trying to fix a engine that is so mediocre on the modern highway.
Swap is on the backburner for now. Other things are priority. When I do it, it will be unique. I will try to do it as simple and inexpensively as possible, and I don't mean cheap and prone to fail..................3B is around 850lb. Currently I'm looking at some engines that are half that weight and make 150hp+. Both Gas and diesel. On the gasoline side I'm amazed at how cheap some parts are becoming IE: new quadrajets on amazon for less than $200 and 2bbl's for around $100, petronix ignitor electronic conversion modules for point distributors are less than $50.
If I loose 400lb of engine weight and ditch 2X lead acid batteries for the 24V setup for 1X12V and buy a lightweight lithium and also replace my custom welded steel front winch bumper with an aluminum bumper.......Looking at loosing 600lb of weight.
This started the gears turning again into the possibilities of a different direction:
https://www.motortrend.com/how-to/blueprint-engines-four-cylinder-crate-engine-ls-head/
