what battery will fit a 4runner (1 Viewer)
forestville, california
new battery
what a difference
stock battery tray needs to be removed
but other than that it fits ....couldnt be happier
fyi same look and made by the same people that make odessey batteries
no more optima reds for me
87 4runner
Dimensions:
Height: 9-1/2 in.
Length: 13 in.
Width: 6-4/5 in.
Product Overview:
Item Weight: 75.0 lbs.
Battery Type:
Battery Group Size: 31M
Temperate Zone: North or South
Transportation Type: Marine and recreational vehicle
Power Configuration:
Voltage: 12.0
Power Ratings:
Amp Hours at 20 Hour Rate: 100
Cold Cranking Amps (CCA at 0 deg.F): 1150
Reserve Capacity (RC): 205 min.
Design & Construction:
Container Material: Polycarbonate/polyester
Warranties & Coverage:
Months in Use Free Replacement: 36
:hmm:I wonder if one will squeeze into a 2dn gen 4runner with v6?
Killer battery. I run one in my FJ40.
I run the everstart group 27 marine battery (mfg by johnson controls) from walmart. Fits into the stock 84-88 toyota tray, without any issue, and costs under $80. I have one which is 7 years old, and still works perfect. I was absolutally blown away this battery works as well as it does, as it replaced 6 dead optimas, a 1 dead odyssey.
dimensions are: 12 1/16" L X 6 13/16" W X 8 7/8" T
I just run whatever the book at walmart says to run. No extra drains on my electrical as if now so no need for a battery that could power the big apple.
That said my truck came with a "hocker" battery. Was so heavy I had trouble lifting it. Said it was a mil-group battery or something like that on the label.
Do you know if that would work on the driver side?
new battery
what a difference
87 4runner
Dimensions:
Height: 9-1/2 in.
Length: 13 in.
Width: 6-4/5 in.
Product Overview:
Battery Type:
Voltage: 12.0
Power Ratings:
i am currently looking at what to put on the drivers side havent seen many pics but you do have to relocate the afm and air box...
one work around i have seen is add a cold air intake and run it on the passenger side back toward the firewall
they had a group 34 where the stock air box was cant seem to find the pic atm
Yup, thats what I got now.... So I have the driver side available....
one work around i have seen is add a cold air intake and run it on the p***enger side back toward the firewall
if you don't like optimas, I think you'll be very happy with a diehard platinum... they're rebadged odysseys :)
