The above link appears to be for just one screwdriver? If so, I would purchase a set of screwdrivers. See Vessel set link below:
This plate with the 3 large JIS screws. View attachment 4051875Remove and seal up with this before installing
Absolutely follow this guidance. Last 3FE water pump I installed I had to do it twice because the new, out of the box, Aisin pump leaked.
Second time is quicker, easier, and a good learning experience.Roger that…I briefly discussed this with CruiserMatt too; and I figured it might be better for me to be safe than sorry. I really don’t want to this twice over LOL.
That is true…Second time is quicker, easier, and a good learning experience.
Kudos on purchasing from one of the specialty vendors in the LC “scene”. You don’t get phone support ordering parts from Rock Auto or Amazon or whatever. It keeps the money in the community and you have a knowledgeable person selling the part. Win win. Go to the vendor section and the small business section (in the classifieds forum) and you’ll see how many folks are out there doing stuff to help these trucks keep living.Roger that…I briefly discussed this with CruiserMatt too; and I figured it might be better for me to be safe than sorry. I really don’t want to this twice over LOL.
To the last bit, yeah some of that debris got in there when I did the first few degreaser wipes. Is it okay for me to just spray in there even though it foams up?It's not really worth rebuilding these water pumps at the moment because there are still quality pumps available even though the OEM pump is now discontinued.
Any of the parts listed in the FSM for a water pump rebuild are long discontinued and are generally unavailable.
That being said, I would keep the old core cuz you never know what's going to happen in the future.
In the picture above, it looks like you've got some debris in the holes for the water pump bolts. Good idea to take a can of brake cleaner and spray them out.
Got it. I can do that; and yessir, I have a digital torque wrench.Yes, spray anything you have into the holes to clean them out. Brake cleaner, WD40. Compressed air - even a duster can you use on your desktop keyboard. You just want them clean and debris-free so you get an accurate torque reading. You plan on using a torque wrench, yes?. Brake cleaner works best for me.
Use a spot of anti-seize on the bolt threads when re-installing. I personally coat the entire bolt with a thin film of general purpose anti-seize.
Also, if you're reusing the old fasteners, wire-brush or wire-wheel the threads to cleans those up.
Agreed. That is a great kit. Going to add this to the tool box!Just my .02 on chasing existing threads: A tap can sometimes be too aggressive and remove material you don't want removed. Depends greatly on the quality of the tap. I much prefer to use a quality Thread Chaser which just cleans up existing threads. This set was recently reviewed on YT and found to be the best 'Value'. USA made. You will find all kinds of use for it with a 40 year old vehicle. I bought the Snap On version before I knew Snap On just rebranded the Lang
LINK
I hope to have an update this upcoming weekend when I’m not working and can finish up. I just got the sealant today from @cruisermatt and I should have a set of Vessel screwdrivers delivered tomorrow.
I’m honestly considering to buy this as well…partly because I’m not satisfied with just “bare minimum”; and I am in no way suggesting that cleaning up the threads with the aforementioned brake parts cleaner or one of the pressurized air canisters is as such (I did BOTH methods last night after work), and that leads into the other reason. I don’t want to do this truck a “disservice”. If I know I can do “more” or “better”, why not.Just my .02 on chasing existing threads: A tap can sometimes be too aggressive and remove material you don't want removed. Depends greatly on the quality and type of the tap. I much prefer to use a quality Thread Chaser which just cleans up existing threads. This set was recently reviewed on YT and found to be the best 'Value'. USA made. You will find all kinds of use for it with a 40 year old vehicle. I bought the Snap On version before I knew Snap On just rebranded the Lang
LINK
