Water Pump roadblock.
Georgia
Good evening guys, I’m back…
I’ll start off with this…
I decided to drive my 60 to work yesterday morning…got spooked by white smoke/steam from under the hood…u-turn, went home and changed vehicles…fast forward to the end of my day, I went and bought new coolant to put in the radiator (that I just changed), and I took a peek at the undercarriage to make sure I didn’t spot a leak…and was met with the water pump weep hole streaming fresh coolant.
I’m on the hunt for a new pump (with oiler cooler and fan clutch) but I haven’t had any luck. I’ve tried Red Line, I’ve tried VTP, City Racer, pretty much the “usual” places…all out of stock.
Does anybody else have any other suggestions? It’d be greatly appreciated.
Cruiser outfitters. I do not think the oil cooler is available, but you can get the rings and washers for it from Toyota, to reseal.
Yeah, everywhere I checked, the oil cooler WP is out of stock; even there.
With that being said, is it possible that it’s just the seals and not the actual pump? Quite frankly I’d like for it to be just the seals given the current circumstances of the market and I’m not about to cheap out on a pump either.
Oil cooler is still available.
If I’m looking at it correctly, there an “Order Parts here” embedded link that takes me back to CruiserTeq, where I’ve already been, and it’s OOS. Unless I missed something
The cooler will be expensive, or it was a couple years ago when I decided to refresh mine. ....assuming your talking about an fj60?
Ourisman Richmond is saying $693! Just for the cooler.
15710-61010
15710-61010
I’m not looking for a cooler, just the pump.
I don't think he's asking for the oil cooler, specifically. He's asking for the water pump that has the nipple on it.
Correct, OP?
Correct.
My bad: you are looking for the 16110-61081-77 oil cooler water pump.
Thats discontinued from Toyota and most other sellers in Aisin form.
You can check out of Japan. Otherwise, Rockauto
RockAuto seems to have one from USMW. Only issue with that is I have no way of telling if it’s correct. Unless I call USMW; which is fine.
I don’t even know where to begin looking out of JP. Let alone how long it would take.
You can contact David Stedman at Japan4x4
I have a fresh shipment of GMB (made in Japan) water pumps with the oil cooler port inbound from Japan, should be here next week. We also have fan clutches, hoses, etc all in stock as well. And we’re just across the state line south of you! :D
We’ve installed a number of the GMB pumps on customer cars in the shop since Aisin went NLA, with good results.
NPW is another good option as well.
I was HOPING you’d see this thread LOL. A friend of mine on Instagram told me about you (I believe I also follow you there too), and I’d much rather deal with someone with a solid reputation that’s literally a stone’s throw away. A turnaround like that would be fantastic.
