Watched LX450 wreck on Elephant Hill - Totalled?
Northwest Arkansas
This past week in Moab, I witnessed a critical driver error result in some pretty extensive damage to a nice LX450. The bad part, is that it was one of those "guided tours" vehicles, and had a couple of paying customers in the back seats. Luckily no one was injured, but had there not been a massive rock wall there, I would've been coordinating a rescue effort. And to add to it, these "guided tour" vehicles all run solo. Had our little group not been there, it could've been REALLY bad, as we were about 3hrs into the trail on a very low-traffic day.
So, here's the story and pics of damage for ya'll to assess.
Running Elephant Hill trail in southern Canyonlands NP. We stop for lunch in a shaded area just before dropping down "SOB Hill" and continuing the trail. It may be hard to tell from the pics (as they never do justice), but it's a pretty tight area with a 3' ledge that you have to decend while making the turn.
[URL="http://i33.photobucket.com/albums/d99/tim_korn_99/Moab%202013/b2f27d17daafe24ac67665caeb7e406b.jpg"][/URL]
http://s33.photobucket.com/user/tim...013/5362d8037dd384ea0c853cce319e92d4.jpg.html
As we're eating lunch, I see a LX450 approaching. Now I met this same guy a couple days prior on White Rim Trail, so I was already familiar with the vehicle. It's well equipped, has diff locks, ect. The driver is/was a nice guy, though he definitely wasn't a cruiserhead. He did mention that he runs this trail several times a week, so he was familiar with the obstacles. Keep in mind that this is the same trail that, at the beginning, has several TIGHT/STEEP switchbacks that require backing down/up as there isn't enough room to turn a cruiser around. So, lets just say that this guy is pretty used to backing that LX into some pretty sketchy areas without a spotter.
It was that reason alone, that I didn't offer to spot the guy through SOB Hill.... Probably a good choice, as I probably wouldv'e been standing in/near the impact zone...
Anywho, he decides to back down the first little ledge on SOB Hill, so that he will be lined up for the next part. Easy enough.
Upon backing off that first ledge, he's very slightly off line, and the rear passenger tire drops a bit more than he's expecting (keep in mind this all happened within a couple seconds so there was no time for me to say anything).
Well, I'm not exactly sure what happened next, and I don't think that the driver is either. My thought is that he panicked when that back tire dropped, and meant to slam on the brakes.
But.... he nailed the throttle instead.
BANG BAM SMASH. Horrible noises that you never want to hear.
He kept that throttle PINNED for about 5 seconds after impacting the immovable rock wall, as you can see by the holes that the tires dug while in reverse...
Here is the aftermath, like I said earlier, he's very lucky that the wall was there. On the other side of it, is a big drop...
As you can see, it's pretty smashed up. The rear doors wouldn't open, and you can see that the top of the rear driver door is sticking out away from the body.
The driver was pretty shaken up, as to be expected, and I just worked on calming him down for a while. The passengers were fine, but I was most concerned for the driver, as it was still a 3hr drive out of the trail, and he was shaking pretty bad.
I went over and did an inspection on the LX. None of the suspension components were damaged, and it was still driveable, so I let him run it.
Here are a few better pics of the rig. And as you can see, the frame is pretty trashed, and it even bent the roof line/roof rack.
So what do you think, can it be saved? :popcorn:
Glad no one was hurt.
That's a beautiful rig, it would be ashame not to at least get it looked at by a (competent) local mechanic and get an idea of the extent of the damage before writing it off. Good thing you were there to help as well.
Weird - i saw that very rig in Moab when I was down there at Easter. The outfit has two of them (maybe more). Shows that s*** can happen anytime, anywhere to anyone....
Yeah, that looks pretty bad. For the body to be kinked that far there is a lot of stuff bent (behind the scenes).
I saw those guys running the trails when I was there for Cruise Moab last year. In fact I saw one on the Elephant Hill run when I did it. The drivers must be pretty competent to be running much of what they do with no sliders and rear bumpers, and keep the rigs looking as clean as they do.
I say if it's mechanically and structurally sound, run with it. If it can be tweaked in a frame machine to get the doors to open and close, it's well worth it. Call the damage, "character".
was the driver on that trail for the first time ?
I have never done that box without a spotter
OUCH! thats a lot of damage. How much running start did he get at that wall? a car length? two?
and could just be the angle but whats up with that USDS front control arm in 3rd to last shot?
looks like drop bracket with high clearance arm :D ....... or fubar'd OEM
It's all about how much you like your vehicle.
The damage looks bad but can be fixed.
Ive seen a freigthliner fl80 frame replaced from front end to rear end for 25 k
Now i am sure this can be bent back without repacing major parts. From your pictures
we cant see any cracks ........
As i said its all about if you love your vehicle
Thats weird how the body buckled like that. I met the owner of the outfitter during Eater Jeep Safari. I think he said he had three LX's he used for tours.
I dont understand the backing up part. If he is experienced he knows an 80 can make the turn at SOB hill without backing up.
Especially now since the Park Service "improved" it for the honeywagon that goes in to service the pit toilets. It's like a freeway through there now compared to what it used to look like.
Yep I did it with you in 1 turn back in '05 :rolleyes: Cheeseman in the background I believe?
Probably about a car length running start, but it was down hill, and pedal to the floor. He was definitely moving when he hit the wall.
I have no idea what's up with the front control arm. I don't remember noticing anything funny about the axle alignment during my survey of the damage, but who knows.
Sent from my iPad using IH8MUD
Agreed, everyone in our little group single shotted the turn in both directions. I asked him why he was backing down, and his response was, "The owner (of the company) says that the ledge tweaks the frame too much, and told us to back down then pull forward."
Yeah, you can imagine what I was thinking when I heard that.... Irony. LOL
In 1978 I took a 1974 3/4 ton Dodge Power Wagon through it. The group I was traveling with was all full-size trucks.
