Unobtainium (10 Viewers)
I've got 5 of these made. We only have after-hours access to the equipment.
One is on reserve for a Mudder, so the other 4 are up for grabs in the Classified section.
Will try to make more, but the total production run will be limited to around 30.
Once you have one @cobraboyHB could probably reproduce them for a reasonable price. He's not around this forum much, but his name is Chris and his email is redvenom@msn.com. He makes radio delete plates and he made me a very convincing pair of orange apron marker lenses once.
I've had a very hard time finding the rear window decal "TOYOTA" in Black with a white center. It goes at bottom of the up hinged rear window on my 1970 FJ40. I found a shop that is making some for me. I thought I'll sell or give away to those who are missing that decal.
Can also add OEM PCV hose and OEM carb throttle return spring.......................
While the front mat effort will be cooking for a while, want to gauge interest around a cargo mat with OEM style patterns. Any color as long as it's black or grey...
(and I won't do the border trim)
View attachment 1199236 View attachment 1199237 View attachment 1199238 View attachment 1199239
I'm a buyer for the cargo mat. How much and when do you think they will be available? I am still hoping for a matching front mat. I bet you could pre-sell 100 of them with $100 up front deposit to capitalize the production costs. I think there is real energy behind a "good" factory correct mat. Add some dynamat or other heat/sound shield and $500-600 would be reasonable. perhaps even more. Keep us posted on the "cooking for a while..." let's move the mats to the front burner and build them, please.
You mean sort of like this? ;)
I was over at @ginmtb 's place this morning trial fitting it in his truck. It looks like a fit so it's going to stay there to get dirty.
Of course the stepping layer is not built yet, but there are a couple of approaches I'm evaluating. More about that later...
Wow - that's what I'm talkin' about! Yeah!:bounce:
Soooo....This project has gotten off-center and started to become reality. Me likes! I've been pinching pennies for the day these things become available.
Roger,that front and cargo mat looks exactly like my CCOT Aussie mat...Also the trim is the same...Do you use similar material?Your front mat looks just slightly longer under driver seat which is better.Also yours is better fit over trans.hump,too.Are you gonna use any insulation under it?
Yup Aussie material; however, there are several suppliers so it may or may not be the same as yours. This is still an interim version, and the trim will go away. I tried a different material previously but didn't like the finish. Not trying to give CCOT a plug, but they're right that Aussie mats are the best.
Insulation won't come with the mat. but it is readily obtainable from a number of sources for around $30.
Looking forward to buying front mats and rear cargo. Please keep up the great work and keep us posted on your SWAG for production. Thank you!
I have an original front matt in my truck that isn't in bad shape (relatively speaking) but would like to keep it that way ... long way of saying I'm in for the report when they become available ... good work, Racer ...
Eventually on I'll just make this part "open source", by putting the design file on Google Drive. Anyone with access to equipment can print their own.
I just installed one of the rear heater fan motors @Racer65 sells and to fit it in my '77 I had to stack up 3 #6 washers under each of the rubber feet. There's probably a better way to get the height right but that's what I did and it works fine. The motor axles are also different (older has a solid shaft with a hole for the fan set screw) but it's not that hard to figure out how to get the fan to sit right. It's nice to have the rear heater working again.
Another one bytes the dust. Just got word that the rear heater motor is now discontinued.
