TWT -- The Wrenching Thread (5 Viewers)
SCIENCE!!!!
He could have just said, cause its a ford....
Help an idiot out here. Can you tell us why it would erode? What is the substance causing erosion? My simple mind goes to water, coolant and oil, but I'm guessing it's a gas since those things don't erode the rest of the engine that contains them. And y'alls silent judging of me is justified...auto shop in high school would have benefitted me.
SCIENCE!!!!
No kidding!! Our hay man was telling us about one of his bigger Fords that the cab has to come off to change injectors I think it was. Something you would not expect the cab to have to come off to do. He told me his next bigger truck will be an older model that has been completely rebuilt. He has a serious dislike for all the new trucks. He has 5-6 of them on the road.
My buddy has a mid or late 2000s expedition (gasoline), and theres an SST required to remove the sparkplugs, and youre bound to break at least one trying to remove them. A tuneup became a very very very expensive thing.
I no longer science, math or music. I simply consume and excrete. I thought I've made clear over the last year.
Well, then you better not show up at Belle Johnston Park again to play with those toy sailboats, because you need science and math for that, and listening to music always helps with sailing. Foo Fighters Station on pandora for my drive down to hype me up, then some mellow Little River Band and Christopher Cross, with a little bit of Marley to get into the "flow"....it must have worked, because i won all 8 races I was in ;)
Now I'll be "wrenching" on at least 2, if not more, of their boats down there (brought one back to rebuild)
"I got science for any occasion. Postulating theorems, formulating equations!"
Beastie Boys
Paul's Boutique
Great sig line material!
Beastie Boys
Paul's Boutique
So we're all gonnna post up the same thing in the 'what are you listening to' thread tonight???
To keep tech... I'll listen to it while organizing parts into my new file cabinet.
More of a Licensed to Ill fan, along with few from Ill Communication, and Hello Nasty
Engine nerds like @Rice, @jfz80 and @mtweller (among others) will like this. Got the 6.0 torn down last night. Block is perfectly fine, no water jacket corrosion. I saw a few spots on the MLS head gaskets that could have been the leak, but it's hard to tell and the leak could have been inbetween the layers as well. Like a dope, I didn't get any close-up pictures of the block mating surface, but I did get pictures of a few cylinders showing the cross-hatch marks from the last time it was honed. I love diesel engines. Block is certified good to go :bounce:
This thing has definitely been apart before, based on the EGR delete, updated stand pipes, updated oil feed and drain lines, newer glow plugs, etc. It's been a while though, found a broken injector connector, a few broken glow plug connectors, harness not restrained in the head in a few places, etc. If the head gaskets have been replaced once, I'm assuming it was years ago and was likely at a dealer, because all the right updated parts were used but they used head bolts instead of upgrading to ARP studs.
Other oddities, this engine has the later style IPR sensor on the injector oil rail, has the later style fuel regulator, later style injector oil rails, later style glow plugs and pistons, but has the early style HPOP. Doesn't make sense.
Either way, will get my parts order together, get these heads off to be reworked and send the injectors off for servicing.
6dCLnekknZSXFnkYRJ33ssoODnUIaYwpECcQMM2NyPYWUQL9B_VjxZfo1ny3aN1pOYNMYdjHggyu_kUOlgdiLQj-3CW6b-CTiXCCqykJqyL6Ob2zaY8e7-Ksp6qMyLCsoFSAontGlWxJ08KKgcuDAZe_upv7xBZcYOgxGAMtqVXBawsXJt5MVcNZ3syYZalUfGrKEDQrjaTOpzSYC12qc0kXT4DhI7tfLeXpSRHg8yI66Zf3oARwZ6yK7XYDK7klOlqLQKhivzLO0UR7EawdqAZ-WZGk_HYee5mui-zwaeJESMV60X0tdCOBzZkK2hMJES376_RJYlszIdyq1s2Byra6IBhVLoQMZEJwkX4Mw0dXy2fsppU16ivFYqAYS7Mq88tmNFYlJ2Ex6MXUa-dy2s-u0-9uFH6h3izQqvSw0urAqdjKW1oL4x2Uz3-TXx5CSeb-OzMWmB587-K9IR1qkh9dH8CLOjdi_ddHbwFkXMMV-8rw9VlFHgVcxhHfZCaLGlgvlMFoEHnILIr8FurbnN4tL4l9ej_82NlBghqwR9ZMpazAHC3UjIhvOkgLx0kI2mvXhSk4bVv4lv4R-S2iylqSF_ksb8Zos3gOng4fKuIEm5lPpLa04w=w2670-h2003-no
XrOhfg_4CkJ5hHLU7lMrBJINH8AFuShekJk9jjp7gYTLVbNCulodV-6cOZlNdeLaadJd2Xj6tHxOMVWGTdT_A2wS01eYBqOhRmKidiYTkq2ZVjdkPnSDRGou-zI2_S5WnmbfH1TPeb4x9iWoWRUKr25TkjKza3mun2RRNyv8wak7da6rEAVLP2HsNAa7qgSZW4xn2foxrRxpJ60AKNqPI61le2kmQfKMPshPCgoa6e3di6G1cwSK6N3mFFbABGCsRs7BkzpBZtW-CAlaMo2X1hPfCwAG6zX2SG1y5kA8q0b6MsywC1cQ-2JMziE8ysC8Su4J9p0ZdBv-D_FogQgODnpsKHC3-1E3bFJwySQNj5fnhCC6SG7ppmeFAfpHAUziS7zlN7Cij1BUxcbQwIuACnCOnawIQ2_MkCO8-jUsieMbksOG_JO7rEkdwJy9OLvyEy8MZuqzYujmn3CRZmL7SuC9YORDTM4dCg3CQJ4BLgjbZUQS6TPNNHh70O6uIjVv76CT2hfPPwK2hRFmgv7iMUsjE4uqqVc6HtwvHUN5grY9P2ASWS0Yx2ZJrHGo9dOfHGEnn6xjwchQoFlYoGVfnoJ_ykY721lH97h1nyjiTSdW9XFtRVf_CA=w2670-h2003-no
QhgSlp84ptFy1Rg-VnX0DYm3uqYgXS89qjaHaWFH7x4pMSkhrELipWdLqr9TOXF0tAcAq_3D1hQqBLmnJjYNb9XiTm0vG_wF2oFRh4DJN7bjrjXEhSPlAT8w23_wlRP3R8BDxGkfQg4lu66bygJA-9xEwGWx-LtOIu_wBr_g_fwT-0AW8QzP8gVQirbcTYBHUT-3FbqLllJEPUsGQpEejNTBhC6ll7N1mBDXH77hWYwe6MprR2whKsYUnrZW79KimqSe1_tLpWLxYMciQLfeGUGaGv_6Ls4YznOfR4uCgDgD8Q38bCc7Yf1RHzjWYFfZsKMWWiBihUFTu_2NF50H2DCJJ_skfEwimEsVANqtS_oqgfhPUIWIpt7JfEYlaFF7vtfWLgtu4JO8waQrSiF5ze2EZukPk-7M5hUh-3iEEt-UcECQDhD3LI3Tx1_gyS9s2JeKE0aS1fi1QxNVcv-SvEePCRs6OYlLCriI3RUqCAaRh8HkuzT6AS-jn8yW_cIMAE9dJ1B5fb6HWPTaKCo7RnNlGbW1mZrM_qohq_0pzLbdiHMqSJlaj1AwNZ_tNCDuOY5_HgFNNPGV_qpuR4bya0hOLPuIMNOFhssPbom1mnhZeCBkkKMS5Q=w2699-h2003-no
_f8VLkSNSBzcuEqABcdMKz1F6Sr9UWxxGSBZwZuEhJm1BLSWayxEkMWToMcGDDtCmNUWTNrqx-nh6inl5ebP1UHmOzJyKaZpj7Hakq_5IAp9xbG4fX0IMFUqX6sJnn2txBknlpIqtNlK-E_q3dEk0bhn2QvTyc-lING3E4_wqsJrrs86QpAFY1EdlgqAU5dodekBdT7sVilaMGwd_Ce198ySmBDkoVOgQu52TMw_6mFmEqpgP4uAmjGoWeWsHjaQB9IiCqu3AfOvAYBjyjPfO33raUEcZp-i1xd3Z4yYdjBKjLb7h2Ntf8rPOYDsa1d8rKuar0gL9RrVHSC2QewdB3LL-2RcQP1QNx-G-R4UP5U706uw8pbJusNS45gBanJFb2R4nTr6OYhYk5kX3yvN2ooHq3H56nRoVrrYz-sEi63J9k-gw6tGOfv74JeaPP7NWXja2gBpkQu3ShOFZSP4ZttUBC8nkoqaxgFG9LP4iuhpcEyyQrljLgTmwc5ffp18oETrQTiLEbBgii13jTPtzcE-XfE0wNWHD2O6xHu-hWVAaiQ_oaZsbtp2AXiUS4FWaV-nBqi97DhhS6tsWF2Gq0RF8stj7MnyiTn16O6DGHrWBUGw7BxTrA=w2670-h2003-no
87X_AOq0A1CA5tehVJSw4saelyJuae4rfHvk-ehne7Vvcj8WMDcFnMMTED0u5Xs7l72vAyGh4anZ-YPb-L6KkYr4pz41niPejdJS8LddVD2iBCo9MGqUJLaq3ck4_l6-3txxtcn4znrOKDlFM86c2M3WQigtrBKQyKdYAKlYPNljl2JJlqRYxlje5tNyckYGC7pkoBAb4EIr42OrDKtaj1bCVecun9PU9cfllqYhdZrrcrqZst6VrRWsYgwx78Yipkt8Yt_Dx3PCGR3yBuwYFrSaZ1ZASnfjJeTrqReN919PZBwYPLy7gGJSp4WMbbeHpHDgVV2ULZ_RpZOrIzQ80NJe4sx6mRihkPz8hgcdgOhDqVGdTd-ndDFSe7Jddr5EpC7AyopsVT7UeS1tHus_EjJg98FRNSL85_E1p-EqLVZV-TkOOUq194G5ZN6Q3EpzxWiuWwiiL4ifh0fNHUMh-fz_uy4dUfJumI7BIHtTVI-bF5EfikGs_MTRgX3FuQ_kB1ZpHA0-D1sGvs6MNJcbhrAAZFWzq9oNj-4E9mLjWHeNFARJBLNYpOuQYK9iSRCd5jUi9lL0PiNdbai5y0QE-8f_NRYM5tXX5XGKoIOL7dmHzq6Ygror1Q=w2699-h2003-no
F7gp-4b-e6tqhZGuQkPUBmbuRxPYbw8Xy4heS_7hqn8gVw00EeH7aG99iDO3pwxdunZeXzHef1LbUikhoyUPGjStBwEQXRyOGRs-XQfGnOkpA9pVN6pLQSXhpUP-Br8ycXoUA_oy28PmxCjeIymST3s3F0kJ9luT92p_957Hcd9BsitDn3S-VQQv0vTVb9TsVOuLF5bm_f5xPqINyKwHO2VlAarejmQuQX7vIUMMxeQ3Z4KG8AHod8_N3Czuf_m3LAQyxh_M8dK1nQvp2WnJy1lgUCkF-GBSqHdC2DY_lk6S22_MN7B6WjcaO07TRa0YfMJ_RfY2lvkhK8mLPU197c1EVfHI_XujcZfcBbAetzPk2qrzSuPFietCFu6eKJ8okrRQz5ciRYv1namOOUC2gTep_sYxy1_vImO1eFI51rNZ_UzXKcJd_Heu2KQG3isJ4uDhtgOcnEMXhQTFtdjdc3hC0eJV-Efq-w4LrFMZ2ihdY0HOXM9UE8LGn8HJk-kXIVqYrob2qNtSmepwnV2bXm3jOIZGMp6pOuFHacsKFPa6l4Gkl-7AEN06JwGdbGO-gEBzRdfQP49TWMBxtrIvK6mdaUfo0u6zJPQSPo3nyQqPvHRYMLcgcA=w2699-h2003-no
ROVbRIaKRYQwiN38dsy8AG1NrJiatdR33IsJomtQNJHuu3xC1blCt0oK4KMIyGsa7dlUlGsg_ZTQD3W-rkHOPnKL07T2cOUVgoQlbu8fr0mxti5_O7XYizW8R_to-1_w2mzAaiZyygaLBb4At-pNTNzhzRJBcti8HsJOh_PzsGfVQM9YeO7QKxrKAZuDxxymzNs0nVQMOPrKGZY6mF2KAWCDZx-8yfa5oP37BMVau-bPS7QwE9bimHAGuHryq4mLAaCCQmslmEBASkxY6tBIbtAAmw-SLcgouMUvORfuEFQ0Rx3X9Gr2v-7IbuYIR64l7N_sOQjt0Rsae8_lvEuMOtwneO-ekGVfZV1yYNV8pu7AF3UGttixvfum6qyxgAMEkOtSpSG5rglfsvH2ZOvGLppDPmjByhuKL2tWMayYmUr5dGmX9PFKsyoc65AekV31gRSO5Kt76m4Ytu1mkkgfX8VVJ8iDeLwaqtLd5Q-eFNonMQFXw6qBnPDAvqaCaf6Kj8X3AdqKj2ywYF2resL0LmQQKG-kLTPEBSqJOokKjYaIzSJ-BoK0lbs_1-iDMfPGcGFBCmZjFQQ-gFp3nxvcmhNsqQzD14VlturMiHNFhw8que_OjgwXQg=w2699-h2003-no
Dude, you have been busy! Wow. I know you're having a blast. I'm diggin all the light you have (and that rockin drill press).
4-bolts per cylinder for a diesel surprises me.
Good luck with the cylinder heads!
BOOST!
I see what the problem was @GLTHFJ60 - your spark plugs are MIA. :rofl:
Great work man. Look forward to riding in the new and improved land yacht.
You guys must be all juiced up today
  • Pick
