Locking T-Handle installed. Carpet and a more elegant solution for the inverter come next week.View attachment 1428568 View attachment 1428569 View attachment 1428570 View attachment 1428571 Got a little more done on the drawer. Drawer built, slides work, put a temporary nylon pull until I decide what latch I want.
Engine nerds like @Rice, @jfz80 and @mtweller (among others) will like this. Got the 6.0 torn down last night. Block is perfectly fine, no water jacket corrosion. I saw a few spots on the MLS head gaskets that could have been the leak, but it's hard to tell and the leak could have been inbetween the layers as well. Like a dope, I didn't get any close-up pictures of the block mating surface, but I did get pictures of a few cylinders showing the cross-hatch marks from the last time it was honed. I love diesel engines. Block is certified good to go![]()
This thing has definitely been apart before, based on the EGR delete, updated stand pipes, updated oil feed and drain lines, newer glow plugs, etc. It's been a while though, found a broken injector connector, a few broken glow plug connectors, harness not restrained in the head in a few places, etc. If the head gaskets have been replaced once, I'm assuming it was years ago and was likely at a dealer, because all the right updated parts were used but they used head bolts instead of upgrading to ARP studs.
Other oddities, this engine has the later style IPR sensor on the injector oil rail, has the later style fuel regulator, later style injector oil rails, later style glow plugs and pistons, but has the early style HPOP. Doesn't make sense.
Either way, will get my parts order together, get these heads off to be reworked and send the injectors off for servicing.
Update?
I've started a build thread over on powerstroke.org to ask questions and whatnot. This truck is now affectionately called "Project Mayhem".
Just got word from the machine shop that my heads were cracked and need to be replaced![]()
