- Thread starter
- #21
Yeah, it's definitely not ideal. Unfortunately, it's a really tight space. To route intake tubing to the front where the stock airbox is, I’d have to delete the intercooler. The stock airbox location is also quite low, making it prone to water intrusion, which isn’t great either. Pretty much chose to go with an intercooler over having a cooler air intake location. Not sure if it's the right choice or not.If you can run the air intake out to a cooler area you'll make gains in spool-up and EGT.
I put a new air-filter housings in one of my vehicles a few years back and ran it for a little bit sucking engine bay air. It really sucked. Boost was slow, EGT was high and I had visible smoke.
When I finished the install and put the intake tube back to the front all that came right.
It might be possible to fabricate a snorkel that exits out the rear of the engine bay and runs between the front and rear doors, similar to the Hiace vans. However, I’m not sure there’s enough space for that, and it would require relocating some other components. Overall, I think this is beyond my current skill level.
For now, I’m going to add some exhaust wrap, a turbo blanket, and a heat shield. I hope these modifications, combined with the intercooler, will help mitigate some of the heat-related issues of having the intake in the engine bay. I haven’t adjusted the fuel screw yet, but my EGTs are really low, and I’m making plenty of boost easily, so I think I have some room to work with.
