Folks,
We all love these old trucks and want to keep them. Problem is, they are old trucks. If someone wants them it's pretty easy to steal them. So do what I did and buy a tracker. I bought one off Amazon for $55 and it cost $12 per month for the service. It has a battery backup that's good for a couple days. It can notify you of start events, stop events, loss of power and you can setup Geo fences so if it goes in or out of that fence you can be notified. Cheap insurance IMO. I installed it behind the radio on mine. I also tucked a Samsung smarttag under the carpet, as a backup locator.
Optimus GV75MG Waterproof Wired GPS Tracker for Motorcycles, Boats, Machinery, Assets
https://a.co/d/2i0tOGR
I’m thinking about doing a kill switch and hiding it, only problem - It doesn’t stop you from stealing the diesels.
Think I’m still going to put them on the gas yoters.
After ours was stolen I put two disabling devices which I believe will deter another potential theft. However, I also believe if they want it they will take it.
The best offense is a good solid defense here on this topic in general .........
- nobody knows if a car or truck has a tracking devise , however its a unique idea on the options table for sure here in this discussion ......
- the
HJ , and BJ folks along with
FJ ones alike are best served when the 1st needed step to any Vintage TOYOTA being stolen is the
ability to gain access to it being denied or at least challenged in a major time consuming way at the very least .......
- keeping ALL 5 Land Cruiser Lock Cylinders and ALL owner operator KEYS in good , SHARP , TRUE-EGDES and ZERO Slop and Free-Play issues from age , time , and
general use after 30-40+ years is more important now then ever before because of just that !
- after all if the
JACK-ASS can't get in , then it ends there , and if they do get inside the passenger compartment via any of the
5 doors or any of the
9 windows ...
- at least a new OEM or currently SOLID condition BARB Wire fence Ignition Lock Cylinder is a 2nd good common sense deterrent as well
- a few TECH-TIPS below :
- keep ALL Vintage TOYOTA Land Cruiser Keys sharp-edged and true to fit , form and function ......
- this spelled out in common sense plain English is dispose of ANY old and worn out keys ,
WORN OUT TOYOTA Keys WEAR OUT GOOD CONDITION TOYOTA Lock Cylinders Pre-Maturely and in a rapid time use cycle's Period !
- keeping a sloppy drivers side front door lock cylinder and the Ignition Lock Cylinder in good fresh working order is a simple 2 step approach ....
- step 1 : insert the red nozzle straw into each and ANY Land Cruiser Lock Cylinder of REAL Name Brand WD-40 ONLY product , the blue , red and yellow label
aerosol can , and depress the tip for 3-5 SOLID Metric Seconds , then wipe any Drip-age if it occurs off the lock face itself , then USING ONLY A FRESH / or Good solid
Original KEY , insert and work it back and forth a few times , remove , wipe the key on both side fresh clean withe cloth and repeat TILL the black ooze is gone and the
Excess WD-40 is ALL Clear as it would come out of the can ...........
- if you repeat this exact procedure at EVERY SINGLE oil change interval 3000K miles , your Land Cruiser Keys and Locks are being well , like .....
WELL F'ing Preserved at there current duty life cycle
- NEVER , absolutely NEVER apply or insert ANY form of Graphite product into this or ANY other TOYOTA locks and keys scenario ,
- if you do your screwing yourself and your Land Cruiser and your wallet sooner rather then later , that CRAP advances the age time and wear tolerances of
anything i mention above as far as PART or PARTS go ..........
- now ..........
- if you have excessive slop , free play or a currently broken lock / locks or worn out keys of any kind whatsoever , Period Correct OEM Genuine Parts Remedy
solutions exist Exclusively via our family run online Parts store or by PM 'ing me here directly on
MUD ...
- NEW OEM Locks RE-KEYED and RE-CODED to match your existing factory KEYS and Factory LOCK Codes
- OEM TOYOTA New and NOS Key Blanks CODE Cut on our state of the art modern computerized NIPPONDENSO Brand Japan SST Key Cutting machine that uses
a digital , and laser guide for
PERFECT -code cuts we stand behind each and every time we ship one or more out to our clients ...
- i am a TOYOTA T-TEN Certified Lock and Key Technician , and a Licensed
Vehicles ONLY Lock Smith ...
thanks for your support ,
Kindly matt
Lock and KEY Re-Key & Re-Coding SERVICE Feature - This Is The Lock and KEY Re-Key & Re-Coding Service...
vintageteqparts.com
This is a Service Link: This is the Step where you choose How Many Keys you would like Cut on...
vintageteqparts.com
NOS Ignition Lock Cylinder 69057-90A05 OEM TOYOTA Genuine Part FJ60 BJ60 HJ60 HJ61 Fits 8/80-1990 NOTE : This is NOT...
vintageteqparts.com
Price is for Qty x 1 Lock pad Gasket ......fyi OEM TOYOTA Lock / Key Cylinder qty x 1 Black...
vintageteqparts.com
NOS Ignition Lock Cylinder 69057-90A08 OEM TOYOTA Genuine Part, NEW OLD STOCK FJ62 Fits 10/87-1990 3F / 3FE engine 3B...
vintageteqparts.com
NOS Drivers Door Lock Cylinder, New Master Keys 1980-1990 FJ60 FJ62
vintageteqparts.com
